11-19-2011, 10:02 AM
ABS/VSC/TRAC Disable Master Thread
In order to avoid loading multiple threads into the Documentation and Reference Thread, I wanted to assemble all the different ABS threads into one that we could load in there, so here goes:
ABS Disable on E-locked 4Runners - '96-'00 and some pre-wired non-locked's)
AKA the Yellow-Blue Wire Mod
ABS Switch - Easy, effective and simple
ABS Disable on non-E-locked Runners - '96-'00 (2 methods)
ABS Disable on older 3rd gens
Updated thread:
ABS disable V2.0 for older 3rd gens (On/off on the fly)
ABS, VSC, TRAC Disable on '01-'02
Disable VSC, TRAC, and ABS without damaging factory wiring
VSC, and TRAC Disable on '01-'02
Disable VSC/TRAC Only
Disabling VSC & TRAC - 2001-2002 4Runner with VSC & TRAC Systems - YotaTech Forums
Disable VSC and TRAC but not ABS on '01-'02
AndyMod 2.0. ABS Remains Active. - YotaTech Forums
A couple guys mention disabling VSC withouth disabling ABS or TRAC, If anyone has a write-up for that, post it and I will add it. Same for any other methods of disabling any of these, post them here and I will add them.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
12-30-2011, 09:06 PM
Just got done with this mod yesterday, i love it! I was so disappointed the first time i went out to "play" and figured out there would be no fun to be had with the 4runners nanny mode. Only took about 35 mins to complete!
02-11-2012, 07:22 PM
Good job. I have to do this soon, as sliding through intersections in the snow is way not fun.
2001 SR5 4X4, V6, 3.4L
12-12-2012, 02:44 PM
Has there been any update to this? Has anyone found a way to disable just the VSC alone on the 01-02?
12-12-2012, 03:49 PM
I just did this one. Took 15 minutes and works great. Disables VSC and TRAC but not ABS.
2002 T4R Limited, 191K miles - OME 883 front - LC 7 wrap/2nd gen sway bar links rear - Detroit Truetrac Diff - Cooper A/T3s - Warn M8000 - ARB Bumper - homemade (er, 'custom') rear bumper w/tire & can carrier - BajaRack - Diff Breather Mod - Hayden trans cooler - Yaesu 2M, Cobra CB - Fridge, off-road trailer with Tepui RTT (real expo poser)In Africa they say: "Buy a Land Rover and it will take you anywhere. Buy a Toyota and it will take you there ... and bring you back home." jannikt on wranglerforum.com - I'm guessing he didn't make many friends there with that line.
12-12-2012, 03:52 PM
Nelsonmd - Thanks for consolidating these links... My ABS was f'ing with me just yesterday & I can't wait to disable it.
I read the first two links - it didn't look like anyone was able to get the Yellow-Blue wire mod to work...? Dylan's writeup (second link) looked like the best option for 2000 and earlier 4R's.
'99 SR5, 5 spd, Bilstein 4600, elocker mod, TBU
12-12-2012, 05:35 PM
Originally Posted by 98OzarksRunner
Second that!
12-12-2012, 05:39 PM
Updated the first post. Thanks for the addition.
Glad people are finally noticing this thread. I thought it was useful, but it got very few views at first...
01-29-2013, 03:28 PM
So does the andy mod 2.0 not work on 2000 4runner with elocker??
2000 4runner limited w/ e-locker and 4.30 gears 180k miles. OME 883/891, diff drop, 4innovations front steel bumper, cbi rear. Stock 265/70/16 cooper discovery h/t on 5 star limited wheels, new wheels and tires to come soon. Audio modifications: Sony HU, 10inch JL subwoofer w/ JL ported basswedge box and Rockford P300.1 amp.
01-29-2013, 03:58 PM
Real Name: Mikhail
Real Name: Mikhail
There is no reason for the Andy Mod on a 2000 4runner as it did not come with the VSC/TRAC
-2001 Sport Edition 4runner 4x4 2nd gen Supercharged-
-1985 Toyota Hilux (Pickup) DLX Turbo - 4x4 5speed w/2LT Turbodiesel
Build Thread
01-29-2013, 07:15 PM
You can also just remove the ABS fuse if you are not good at doing wiring. But then it's always off, I was having a problem with my VSC/Trac coming on randomly, I think I have a wheel sensor going out on one of the wheels.
Just remember that ABS fuse is bolted into the box and a bit trickey to remove. The dash lights are kind of annoying but I think i'm just going to pull the LEDs when i wire in my ARB compressor/locker.
ABS on these trucks is pitiful.
85 Xtracab, 3Link Front, Marlin Dual Ultimate, Double Locked on 37s
08-17-2013, 08:46 AM
Beeping truck..
So I'm new to the forum. I'm on my third t4r. A 1990 .. A '97 limited and now a 2002 badlands. The 02 seems to have more fancy computerized gadgetry than I used to...
I was out on some logging roads on the weekend (2002) and if I was a little too fast though washboard washouts the truck would beep at me.... Beepbeepbeep....annoying as ...... What system was doing this and how do I turn it off... Or should I leave the system on and disable the beep? The truck handled great.... Any ideas or comments from those of you that have been playing with this longer than I would be appreciated
Dan
11-05-2013, 08:28 PM
Real Name: Sammy Swanstickler
Do you have to put a switch in? i live in AZ where there is no snow, so I really don't need it on ever. I just want to cut the wire.
11-05-2013, 09:10 PM
EDIT: You just have to cut the wire.
11-30-2013, 01:11 AM
I think you just have to ground the wire.
OK, that makes sense. Thanks!
