Old 07-30-2021, 12:24 AM #1
domhanna domhanna is offline
domhanna is on a distinguished road
Transmission help… I think my clutch went.
I was driving today and heading up a hill (already doin like 35/40) I added some throttle to get it up the hill in 4th but I was still slowing down so I downshifted figuring I guess I need a bit more. Get into third up to about 3k it pulls and then nothing… revs climb but no acceleration. I think oh just a little clutch slip no big deal I’ll figure it out later. Take my girlfriend out for a ride and going up another hill I feel the same thing. Now I’m worried. On the way home no problems until I hit another hill… this time it’s bad nothing in third or second. I roll to the stop sign and I’m smoking. Alright I’ve burnt the clutch quite a bit. It smells terrible. I don’t know much about servicing a manual… is this something as simple as I don’t have enough trans fluid or do I need a new clutch or is it even worse?
I got it towed to my mechanic but I just wanna have some knowledge before talking to him.
domhanna is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 12:42 AM #2
TucsonMike TucsonMike is offline
TucsonMike is on a distinguished road
Sounds like you will need a clutch job. How many miles do u have on the clutch?
Good luck
MikeM
TucsonMike is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 12:54 AM #3
HiLife HiLife is offline
If you overheated the clutch bad enough, you will have cracks on clutch wear surface of the flywheel. If the flywheel is really over heated, if will be heat tempered and blueish color. It may even have deep cracks in it to where no resurfacing will be enough to get rid of it. You may need a flywheel too.
The pressure plate and disk is toast, literally. Those and a new release bearing and you should be good to go.
If you have extra coin, you could also replace the rear main seal of the engine and the input shaft seal on the trans while the engine and trans are separated.
Old 07-30-2021, 02:58 AM #4
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
The original clutch lasted 2 owners and 170k miles before getting to me already messed up. Just before I replaced the clutch it felt very short and sensitive.
Pyral is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 08:41 AM #5
Good luck
MikeM
I just bought this truck not sure if/when the clutch was last done. I definitely made some mistakes when buying this and should’ve dig deeper into the transmission.
Old 07-30-2021, 08:41 AM #6
So how much would this run me?
Old 07-30-2021, 01:52 PM #7
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Swapping in a used manual transmission may also be an option, but they can be very hard to find due to the auto transmission guys snatching them up and putting them in.
326WHP 347TQ
Old 07-30-2021, 05:54 PM #8
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
It’s going to be around 8 hours shop time at a shop that is well set up to do it. Plus materials of course.
I inquired at a clutch specialist shop who said they could do it in 1 work day. I did it myself with a floor transmission jack in 18 hours working alone.
If caught early you could have got away with a clutch kit for a couple hundred. But it sounds like you need a flywheel now too.
It’s not a cheap repair but if you are good with a standard you’ll never have to do it again. Edit: It'll be a long time before you have to do it again.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 06:30 PM #9
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I agree with the others. My 5 speed clutch got so bad that it would decamp before I pulled the transmission out.
Mine was bad when I bought the truck and the PO tried to hide it by adjusting the pedal and putting an extra spring in. The dead giveaway was the cruise control would've work.
My flywheel is not only blue and has cracks in it.
So yes what you are experiencing is a warn out clutch.
brillo_76 is online now   Reply With QuoteReply With Quote
Old 07-30-2021, 06:59 PM #10
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
If you have the space and tools, do the job yourself. If you bring it to a shop, be prepared to part with a decent amount of money.
Old 07-30-2021, 07:02 PM #11
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I bet the previous owners knew it was going out. It's way too convenient that it goes out on you right after you bought it. They didn't want to spend the money on the repair so they put it up for sale. This shit happens all the time.
Old 08-02-2021, 04:44 PM #12
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Why would he need to swap the transmission for a burnt clutch/pressure plate/flywheel? Am I missing something?
Old 08-02-2021, 07:21 PM #13
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
IDK why would you replace a transmission the only thing wrong was the clutch went out? Its a wear item that will eventually get used up like brakes.
I just checked my vehicle records, didn't replace the clutch like I thought, replaced the spring because it was worn to the point it didn't return to position (probably why it felt short).
Old 08-02-2021, 11:30 PM #14
Real Name: Jerod
Real Name: Jerod
Sorry I think I was a bit tired when I posted last and read it wrong. I thought he was asking about the transmission, not the clutch itself.
326WHP 347TQ
Old 08-03-2021, 08:35 AM #15
Real Name: Patrick
Real Name: Patrick
No worries lol just had me wondering what I missed
bit , clutch , don’t , hill , i’m
Help? Clutch DIY stalled... Transmission won't align denvermaxd 3rd gen T4Rs 16 05-21-2016 09:54 PM
HELP!!! Transmission or Clutch??? Csaszar 3rd gen T4Rs 13 03-03-2016 12:11 PM
5 speed clutch/transmission diagnosis 1blink 3rd gen T4Rs 7 07-16-2013 07:02 PM
clutch/transmission erik_thetruck 4th Gen T4Rs 3 09-03-2007 12:35 AM
