08-31-2021, 06:29 PM
![DenverAirport's Avatar](https://www.toyota-4runner.org/customavatars/avatar639626_1.gif) |
Cranks fast when hot, skips.
Hey guys. When my engine is hot (say I'm at a gas station, turn the engine off to fill up and then start the engine again) it will crank over quickly and make a faster, sputtering sound. Sometimes it will sound like it's skipping in the process. It always starts (knock on wood) but the speed of it almost made me question if there was a leaking injector or something?
Could this be a potential sign of starter failure? I'm considering ordering a rebuild kit (or a reman with the higher wattage option) as the starter looks dirty as hell and I imagine the contacts won't necessarily last forever (haven't been replaced and now at 250k miles.)
Here's a video of the sound, not the easiest thing to hear but may give some reference.
IMG 5516 - YouTube
99' SR5 "Highlander Edition" - 301k - 4WD, Factory rear locker, 2.5" Dobinsons IMS lift, SPC UCAs, CJV 9168 TR axles, 199mm TBU, Tom Wood's driveshaft, eimkeith PCK, Aluminum Koyorad, Ultragauge
97' Limited - 250k - Stolen & Found (and Sold) - 4WD, 3" Billstein 5100 lift with OME 881, 890 springs, Diff drop, Camburg UCA's, 231mm TBU, Tom Wood's driveshaft, eimkeith PCK, Champion radiator, Ultraguage
08-31-2021, 09:35 PM
![spartacus's Avatar](https://www.toyota-4runner.org/customavatars/avatar50279_1.gif) |
IMG 5516 - YouTube
Sounds like a good start to me. Its not buzzing or screeching or clicking. Rebuilding starter is good practice and part of maintenance.
09-01-2021, 02:27 AM
Sounds like a good normal start for me too.
09-01-2021, 10:42 AM
If the motor is rotating normally while trying to start it's not the starter.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
09-01-2021, 12:14 PM
![Devbot's Avatar](https://www.toyota-4runner.org/customavatars/avatar549924_9.gif) |
Real Name: Devan
Real Name: Devan
Sounds normal to me
Y2K Highlander Millennium Silver 3.4L auto @ 320k and climbing ![cheers](http://audiokarma.org/forums/images/smilies/beerchug.gif)
09-01-2021, 05:23 PM
![gamefreakgc's Avatar](https://www.toyota-4runner.org/customavatars/avatar115347_1.gif) |
Real Name: Jerod
Real Name: Jerod
I didn't hear anything out of the ordinary except for that exhaust drone or whatever was going on in the background. Starting up quickly isn't a bad thing.
A bad starter will give you the opposite, a 'click' and nothing else then will start on the next try.
09-01-2021, 09:57 PM
No buzzing or clicking at all. I'm going to rebuild the starter regardless for this reason -- might as well I'm going to have to do it at some point!
09-02-2021, 09:33 AM
![shadow247's Avatar](https://www.toyota-4runner.org/customavatars/avatar80102_1.gif) |
Mine is the same. It starts up really quickly if I start it back up after running and being fully warmed up.
When I put a new Alternator on, it really started cranking fast. Try cleaning your battery terminals and Alternator Connection.
But everything sounds normal to me.
The 4Runner Show
09-02-2021, 11:01 AM
Rebuilding a starter is only part of maintenance if it needs rebuilding.
It is NOT part of regular preventative maintenance.
09-03-2021, 01:44 AM
Good to hear this. I just replaced my alternator as well + I changed my batt and terminals at the same time. I cleaned my alternator connection when swapping but it was definitely really cruddy.
