NachesPass4x4
Would like to get some opinions here.
Long story short a family member bought this 2000 4runner, 3.4, manual trans, 148K miles. They probably paid to much for it and now I have the opportunity to buy it.
They have put a few thousand miles on it and the engine seems to run good. "check engine" came on a couple times but a new 02 sensor and air flow sensor cleaning seems to have resolved that.
The sun roof was leaking when parked out in the rain but just cleaning up the seal seems to have fixed that.
Some of the suspension bushings will need replaced.
The rear axle housing is pretty bad, so probably replace that.
The frame looks ok. Only rust looks to be surface rust.
The body however has a mess brewing on the rocker panels in front of the rear wheels. Would be nice if I could wire wheel this to clean metal and paint the rockers with raptor liner or something. Not sure if the rust is coming from inside or out.
Rear passenger door has some damage but works fine.
Tires are bald, so needs new tires.
Interior is pretty clean.
T case is leaking. Hopefully just a shifter gasket, looks to be coming from up top.
AND of coarse a mystery issue... a vibration in 5th gear. Appears as soon as you shift into 5th. For now I will just assume it needs transmission work. The rear driveline has been worked over by a local shop, I assume in an attempt to fix the vibe.
So if you have read all this let me know what you think. What should I pay for this thing? What kind of a mess am I getting into? I'm used to working on old trucks, so I will be doing the work myself, other than the transmission rebuild (If needed). I've been DD'ing and 84 4x4 pickup for the last 14 years and this looks a little more comfortable.
