A few months ago I installed the OME Stage 1 lift kit (881 front an 890 rear). After the lift I put on 265/75/16 KO2 tires, which is about 1" larger diameter than stock, and had it aligned at Toyota dealer.
All seemed fine for first 6 weeks or so.
But now the left front sounds like its rubbing or almost like it's bottoming out the suspension any time I go over small potholes, speed bumps etc. It's definitely not actually bottoming out and the ride is otherwise fine. We aren't talking off road here. Just small driveway potholes cause this. As does basically any parking lot speed bump, even at low speed.
It also doesn't appear to be rubbing. But that's just me looking for any signs there is rubbing in the wheel well area (ie areas that aren't dirty). It also has a sound more more similar to like an overloaded car bottoming out over a speed bump sort of thing.
It's just the left front that seems to be having this issue. Anyone had this before? My instinct was maybe the suspension settled a bit and the 1" larger tires were rubbing, but I don't see any evidence of rubbing. Last week I added the 5mm spacer that came with the kit, thinking if it was rubbing that started due to settling of the suspension, this extra 5mm would make a difference. But doesn't seem to have.
Anyone had this after an OME or other lift? Any ideas of things to look for?
I think it’s unlikely tire rub. That size should be fine on all 3rd gens at stock height or taller. Not sure what it is, but I think you can probably rule that out.
Thanks. Yeah I'm with you there. I see no evidence anything is rubbing.
