Old 01-18-2015, 12:32 PM #1
mustangaustin34's Avatar
mustangaustin34 mustangaustin34 is offline
mustangaustin34 is on a distinguished road
Rear License Plate Screws/Bolt Size
One of my rear license plate screws has broken off (rust) so I'm going to head down to LOWES to see if I can match one up. Checking to see if anyone can provide me with the size of the replacement and if you switched over to a stainless-steel bolt? Thanks.
mustangaustin34 is offline   Reply With QuoteReply With Quote
Old 01-18-2015, 12:44 PM #2
ILRunner98 ILRunner98 is offline
ILRunner98 is on a distinguished road
Bolts should be 6mm bolt X 1.00 thread pitch. Always drilling these screws out at my dealer. we install plastic screws so if they ever break again they are really easy to drill out.
ILRunner98 is offline   Reply With QuoteReply With Quote
Old 01-18-2015, 03:59 PM #3
Nervo19's Avatar
Nervo19 Nervo19 is offline
Nervo19 is on a distinguished road
Nervo19's Avatar
I take a small drywall anchor and clip it so it's short and insert it into the holes. I have a big assortment of stainless steel screws and washers from the boating section of Walmart. I use those to hold the license plate. Most of the trouble with license bolts comes from two dissimilar metals. The plastic anchor isolates the two metals. The stainless never rusts and looks good. The dealer bolts rust.
1989 4Runner Build thread:http://www.yotatech.com/f199/nervo19.../#post52231244
2000 4Runner & 2000 Tacoma TRD Off Road
2008 4Runner & 2016 Tacoma 4x4 Dbl Cab TRD Sport
Nervo19 is offline   Reply With QuoteReply With Quote
Old 02-25-2015, 03:17 AM #4
Smokey McPot Smokey McPot is offline
Real Name: Scott
Smokey McPot is on a distinguished road
Real Name: Scott
did you ever find those plate screws... can you tell me the correct size, mine are rusty af and my local Ace can't match 'em
Smokey McPot is offline   Reply With QuoteReply With Quote
Old 02-25-2015, 09:05 PM #5
4R1998 4R1998 is offline
4R1998 is on a distinguished road
Bolt size
M6 with 1.0 threads and 10mm long.
4R1998 is offline   Reply With QuoteReply With Quote
Old 04-09-2021, 04:00 PM #6
wjamyers wjamyers is offline
wjamyers is on a distinguished road
I ordered these according to your spec:
https://www.homedepot.com/p/M6-1-0-x...1544/310351607
They just test-fitted fine. I'll put anti-seize on them when I finally install my new plates.
To remove the old ones I had to soak the right one repeatedly with CRC Freeze-Off for about 5 days:
Since I'm replacing ancient plates I bent the old plate's edge back with a hook to create a little well which I could dump the freeze-off down (put a paper towel behind the plate across the bottom to catch excess). With each application, I would open the door and leave it up so the freeze-off would soak DOWN into the screw. I'd leave it like for a few hours, then do it again, leaving the door open most of the day. I started last Saturday and finally yesterday the screw came loose with minimal effort.
1999 Toyota 4Runner SR5 Highlander 5MT
2000 Toyota 4Runner Limited Automatic, ARB, Schrockworks, OME 2.5-3", 255/85R16 (33")
wjamyers is offline   Reply With QuoteReply With Quote
Old 04-22-2021, 11:52 AM #7
Mike_Romeo_Bravo Mike_Romeo_Bravo is offline
Mike_Romeo_Bravo is on a distinguished road
I can confirm this is the correct size and thread pattern. Just did this the other day. Also had to re tap the threads on one of them since they were so damaged.
Mike_Romeo_Bravo is offline   Reply With QuoteReply With Quote
Old 04-24-2021, 02:20 PM #8
MAD 69's Avatar
MAD 69 MAD 69 is offline
MAD 69 is on a distinguished road
MAD 69's Avatar
Several of mine broke off as well, they are now attached with zip ties - real classy looking, and other way to get these bolts out? I bought a set of “speed outs” as seen on tv ads, they didn’t do sh!t,
98 T4R SR5 V6 4x4
23 T4R TRD OR Premium
MAD 69 is offline   Reply With QuoteReply With Quote
Old 04-25-2021, 11:41 AM #9
This is what mine looked like when I bought it.
Old 04-26-2021, 10:59 AM #10
Start with a small sharp drill bit and drill a hole through the center of each bolt. Then go up in sizes of drill bits until you end up with the bit needed for your tap and cut new threads in the hole you just drilled. Use plenty of oil while drilling and taping.
Old 04-28-2021, 01:59 PM #11
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
I've done this method many times working at a dealership.
Old 10-28-2021, 09:17 PM #12
dawudih's Avatar
dawudih dawudih is offline
dawudih is on a distinguished road
dawudih's Avatar
The dumb bastards at Ft Bend Toyota of Richmond, TX used lag bolts on my rear plates.
2015 Trail
dawudih is offline   Reply With QuoteReply With Quote
Old 10-29-2021, 09:06 AM #13
I used stainless bolts as replacements.
Old 10-29-2021, 09:27 AM #14
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I use stainless as well.
Old 10-29-2021, 10:22 AM #15
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
Working at a dealership, I can tell you one thing for sure. The bolts rusting is only half the problem. The nut-sert on the vehicle is just painted steel and once you break through the paint - by threading any metal fastener into it - it too will corrode.
As other have already stated, plastic bolts are really the way to go. (That's all we use.) But I always apply a dab of corrosion resistant grease to the threads before I put everything back together. This will at least slow down the corrosion of the female threads.
Too Stroked is offline   Reply With QuoteReply With Quote
License Plate Screws/Bolts MaliciousClout 4th Gen T4Rs 11 06-30-2018 11:37 AM
License plate bolt rust spyne Problems & Warranty Issues 5 06-30-2018 11:33 AM
need some help - license plate screws stuck theliman Maintenance/Detailing 8 01-09-2014 06:50 PM
rear license plate bolts size? Pepedog11 4th Gen T4Rs 3 07-11-2012 02:46 AM
Repair Bumper Holes (license plate screws) jpless Maintenance/Detailing 2 05-13-2010 06:55 PM
