Quote:
Originally Posted by RodrickHeffley
So i'm 17 and on a tight budget. I also have no clue when it comes to anything suspension related.
I want to get some rear springs to reduce the good old sag, but I don't know what to get. I want to get a 2 inch lift in the future but i can't afford that yet. Are there springs I can use to negate the sag but I can use on the lift?
Unfortunately I can't capitalize on the sag recall...my vin is literally the 4th vin after the deadline.
Help??
If you want dirt cheap then id recommend springs from rockauto. Not sure what your budget is but OME springs are about $190 bucks and will be what you want with the 2 inch lift.
Id recommend OME 906 or 890 for the 2 inch lift. Just keep in mind that they will be stiffer than stock. If you haven't already id look into rear shocks as well.
What is your goal with the car? Offroader? Daily with occasional off-road?
Ive been modifying cars for years and my one piece of advice is gonna be to buy what you originally wanted to start with, Otherwise your gonna end up wasting a lot more money. Sure the OME might be a lot more than $40 Moog springs you can find on rock auto but within 6 months I had to slap a 1.5in spacer on them to level out the sag, which cost me another 60 bucks, which could have been used towards the OME, Just my .02
