10-12-2021, 12:31 PM
Transmission kickdown cable broke?
Recently I installed the TRD Supercharger on my 3.4. First thing I noticed when driving it (other then the power increase) it was shifting hard from 1st to 2nd. Jerks the whole truck. I've played around with the cable numerous times to try and find the right adjustment. After i adjust normally it shifts pretty smooth a couple times then it will work its way back. The harder I accel from 1st to 2nd the less jerky it is..
As you can see in the pic, those little needle grooves will not stay inside the metal piece like the cable is too short. When I adjust it will stay in there until I start driving for a bit thus making the shifting hard i believe. How can I get those grooves to stay in correctly?
2000 Limited 4wd Supercharged with E-Locker
10-12-2021, 01:34 PM
I think it’s time to replace the cable
10-12-2021, 02:17 PM
I read somewhere that its an internal cable in the transmission so you can't really replace it?
10-12-2021, 03:17 PM
Real Name: Patrick
Real Name: Patrick
Time to replace the cable for sure. You'll need to remove the transmission pan, transmission filter, and the valve body in order to replace the cable where it connects in the transmission. Here's a 2000 FSM: 2000 4Runner FSM - Printable - Google Drive The information you are looking for is in section 25 and then page AT-16.
10-12-2021, 05:46 PM
Thanks! Great info. Already ordered new cabl, should be here tomorrow. Will advise after install
10-12-2021, 06:03 PM
Real Name: Jerod
Real Name: Jerod
Dang, I've never seen that before.
When you install the new one, you have to loosen and even bend the transmission cable bracket on the engine hanger. Don't be afraid to loosen bolts and twist it to where you need it. It's a very tight fit but it does fit. Also, always pick the most direct route around hoses and wires.
10-12-2021, 06:54 PM
Yeah, I was reading the fsm and it kinda scares my taking the valve body off. I dont know maybe its not that bad.
10-12-2021, 07:46 PM
Be meticulous with the fastener locations and torque values on re-assembly. It won't be bad as long as you enjoy ATF showers...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
10-13-2021, 02:25 AM
Real Name: Jerod
Real Name: Jerod
I've done it twice. Actually, more than twice if you count dismantling transmissions for scrap. You'll need an accurate torque wrench and patience but it's not impossible by any means. It is an absolute mess though. Finally a good use for all that surplus PPE stuff, a face shield would be handy!
Nothing good will happen running the vehicle as-is indefinitely. It needs to be fixed.
10-14-2021, 12:44 PM
So I’m almost done installing the cable. The cable is too short . I have all the slack out.. if I pull too hard I feel like I’ll break it. Idk what to do at this point. It’s like the supercharger is too tall for the cable
10-14-2021, 01:06 PM
Any chance you got the 3rz cable instead of the 5vz cable? I think the throttle body on the 3rz is a bit closer to the trans, so the cable would be shorter/different.
Otherwise, I'd say follow gamerfreak's advice - make sure the cable is following the most direct route from the trans up to the throttle body.
10-14-2021, 01:10 PM
It’s the 5vz cable. Using the most direct route it’s too short
10-14-2021, 03:46 PM
Also, If anyone plans to do this you do not have to remove the valve body. Just the pan and you have access to it. Pretty simple job
10-14-2021, 04:30 PM
Real Name: Patrick
Real Name: Patrick
Did you compare the old and new cable before installing the new cable?
10-14-2021, 04:46 PM
Sure did. It at lined up. I managed to get it on there but it seems too tight
