Old 10-16-2021, 03:37 PM #1
JamieG JamieG is offline
JamieG is on a distinguished road
Dashboard brake light
The brake light constantly goes on the dashboard which I can make go out by wiggling the emergency brake switch in the pull up handle to the right of the driver.
This started happening a few months ago but now it's getting annoying.
I had the rear shoes on the fifteen inch wheels replaced about two years ago but this started happening a few months ago.
Is this a typical problem with a known typical place to look for the problem?
How can I adjust it so that the light doesn't go on while driving over bumps?
JamieG is offline   Reply With QuoteReply With Quote
Old 10-16-2021, 04:41 PM #2
How low is your brake fluid?
Old 10-16-2021, 06:55 PM #3
spartacus's Avatar
spartacus's Avatar
Brake light is also a warning light for malfunctioning alternator.
Old 10-16-2021, 08:02 PM #4
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
check brake fluid level first. If fine and have scanner avail scan for pending codes. If not...alternator is a good guess of what's to come. Usually it'll intermittent flash the battery light though not the brake. But I've been fooled before.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 10-17-2021, 06:39 AM #5
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
If wiggling the parking brake lever makes it go out that kind of sounds like there’s something wrong with the switch on the parking brake
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 10-17-2021, 11:29 AM #6
Those random occurrences had me fooled and it ended up being a sticking float. It’s simple enough to bend the tab that turns on the light.
Old 10-17-2021, 12:47 PM #7
Outrider Outrider is offline
Outrider will become famous soon enough
I found that if my brake fluid reservoir is only a mere 1/4" below the full mark, it causes my brake light to come on. If yours isn't completely full, first top it off, before checking anything else, and possibly prevent doing other work that might not accomplish anything.
Simplest things first is a good motto (that I don't always follow).
'99 SR5 V6 2WD named Jolene / In the T4R 200 Club
Outrider is offline   Reply With QuoteReply With Quote
Old 10-17-2021, 01:02 PM #8
And if it’s low check your brake pad ware.
Old 10-19-2021, 12:19 PM #9
Thanks. That was my thought process too. Why would wiggling the ebrake lever make the light go out for a while?
Thanks. I think that must have been it because the fluid level was at the minimum, and when I topped it off, the light (so far) has stopped flickering.
Also sometimes worn brushes in the alternator will trigger the brake light. If you pull the lever and the brake light gets brighter then that points to the alternator
Thanks. This is amazing information. I don't see HOW the alternator is even close to being involved with the brakes but I believe you.
Toyota wouldn't mix those completely different systems on purpose - would they?
How are they intertwined?
Old 10-19-2021, 05:58 PM #10
spartacus's Avatar
spartacus's Avatar
Thanks.
The brake light indicates low fluid but also when the alternator is under charging or over charging. When the alternator is under charging below 13.5 or above 14.5V The L out put goes low or zero resulting in negative voltage to charge and brake light warning light, turning them on hence after a while the battery light should also come on.
ago , brake , dashboard , light , problem
2h light on dashboard won't go off!?!? runner mike 4th Gen T4Rs 4 11-25-2017 02:00 PM
2h light on dashboard won't go off!?!? runner mike Problems & Warranty Issues 0 11-24-2017 08:04 PM
Dashboard light out octanejunkie 3rd gen T4Rs 9 08-04-2016 01:18 AM
No light in dashboard.. 90' T4r V6 hjalti_gto Classic T4Rs 8 12-23-2010 11:12 AM
