Old 10-27-2021, 02:05 AM #1
slomatt slomatt is offline
slomatt is on a distinguished road
Can you help identify this electrical plug behind the PS resevoir?
While flushing and filling the power steering fluid on my 3rd gen I noticed an unplugged electrical connection behind the power steering reservoir and above the A/C compressor. Does anybody know what this is for?
I have a 2000 Sport SR5 5spd. I'm guessing this plug is for a feature not included on my truck.
Thanks
http://www.blankwhitepage.com/galler...c/IMG_0761.jpg
slomatt is offline   Reply With QuoteReply With Quote
Old 10-27-2021, 07:39 AM #2
Vansnxtweek's Avatar
Vansnxtweek Vansnxtweek is offline
Vansnxtweek will become famous soon enough
Is is the sensor actually connected to the p/s pump? Not 100% sure what you are referring to being there are multiple connectors in your picture. If its the one on the P/S pump I think this may be it....
Originally Posted by phattyduck View Post
PS idle-up switch. If the power steering pressure goes up high enough, it tells the ECU to slightly bump the idle up to compensate for the increase engine load the pump puts on the engine in those situations.
01' SR5
YouTube: I make 3rd Gen 4Runner videos..among others...
https://www.youtube.com/c/TheChapMX/featured
Vansnxtweek is offline   Reply With QuoteReply With Quote
Old 10-27-2021, 09:26 AM #3
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
@slomatt as others have said, the pink wire behind the power steering reservoir is likely your power steering idle-up switch.
If you need to repair it, the part numbers are:
- 9098011428
- 8299812440
One part is a connector housing and the other is a wire with the connector attached.
Here’s mine after repair:
When your PS idle-up switch is working, your RPMs will briefly increase a little bit when you are idling or going very slowly (like a driveway or parking lot), and you crank the steering wheel.
EDIT: I should add that the original connector housing looks like yours in the photo, and the replacement connector housing is bigger and gray like in my photo. But it works. I have a 2000 SR-5.
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 10-27-2021, 02:11 PM #4
Have you tried plugging it into the matching connector about 2" away from it?
(yes, PS idle-up switch)
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-27-2021, 05:38 PM #5
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I laughed way too much at this lol
Old 11-05-2021, 01:39 AM #6
Thanks for all the replies. I was in a rush when finishing up the power steering flush and completely missed the connector. Doh. Based on the amount of dust in the plug it's been disconnected for a while, probably since the timing belt was changed.
Old 11-05-2021, 02:07 PM #7
Luckily, it is probably the least important plug related to the engine...
electrical , guessing , plug , power , steering
Identify this plug Cogs87 3rd gen T4Rs 7 05-27-2020 04:25 PM
Can you identify this electrical plug? tundrayetti Classic T4Rs 4 01-22-2013 11:09 PM
identify this plug TN_Soljah808 3rd gen T4Rs 3 06-23-2012 08:49 AM
Help me identify this plug g.s 4th Gen T4Rs 4 07-10-2010 02:21 AM
Identify-the-plug-game jacal 4th Gen T4Rs 6 04-03-2006 10:12 AM
