Old 07-31-2023, 01:24 PM #16
Originally Posted by brillo_76 View Post
Nope. It's not cost effective... Plus it's good to have new skills. Just get a good 220 mig. Plus lots leather so you don't scare yourself up. Weld burns leave scares...
I welded mine with a Millermatic 130a 120v. but would love a 220v big boy.
Old 08-01-2023, 09:28 AM #17
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
Originally Posted by toverturf View Post
Outboard Shock Relocation (OSR) – OPT OFF ROAD You could just get this and outboard them though that's a lot of welding and you'd need new shocks so more money. You wouldn't have to worry about those old shock mounts anymore though and it's a lot easier to remove shocks.
I'm intrigued. I'll keep this in mind for when I need to redo the rear suspension...
JohnMc is offline   Reply With QuoteReply With Quote
Old 08-01-2023, 11:39 AM #18
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
If you can you want to upgrade to 220-240v migs.. Makes welding on these frames easier.. :-)
Old 08-01-2023, 11:40 AM #19
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I may do this i haven't decided yet as I am at that point with one of mine..
Old 08-01-2023, 12:46 PM #20
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
This ^^^
110 will suffice, but it's a little tricky and a pain in the ass for those just learning. 220 will service you much better. They can do everything 110 can and more
You can always rent a welder too, some suppliers are dirt cheap. My work rents a Dynasty 800 from Central Welding Supply cause it's wayyy cheaper than buying - you can rent it for 4 years straight and STILL be below its purchase price
Old 08-01-2023, 03:03 PM #21
Snowbound customs makes them also and are cheeper and just as good.
Old 08-01-2023, 03:13 PM #22
I’d love to get a big boy welder one day when I have the electric for it.
But I don’t see how a 220v would make it easier for the thickness I was welding…….
Clean the metal, volume to “11” (highest heat range) and dial in the feed rate tacking it in position. Then burn it in…….
Old 08-01-2023, 03:30 PM #23
I'm curious about the shock geometry differences between the two with one being mounted well above the frame, and the other on the frame.
Old 08-01-2023, 05:13 PM #24
They have info about their mounts on their site. I think instagram only. I’m happy with mine and they look similar to how I would have made them.
The tube stile may be just for show or for longer length shocks.
Old 08-01-2023, 10:26 PM #25
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I welded with both 110 and 240. It's the higher amperage that helps. The higher amps and weld controllers that help with rusty metal that can't easily be cleaned because of location or nothing left.
For example, some brackets are heavily curved and contours that can't easily be replicated or replaced. So you litterly have to mold and melt what's left with the new weld to make your piece.
My old generic 110v really didn't have enough output amps to weld 1/8 plate into good metal to repair things effectively.
So I went to a Lincoln mp210, which has newer models out now that do all my welding needs. I also only use Lincoln wire, which for me works the best.
Most folks suggest using Flux core wire wire on rusty oxidized metal, too. You can, and it will work. However, I only weld it with shield gas now because I get better metal penitration with it. Along with a lot less welding splatter.
This is just me, though. I also welded probably 4 or 6 frames now with various methods. All dell different angles with even welding upside down.
My preferred method is still internal frame plating. However, those safety caps do work well, provided you get the inside of the frame cleaned out and rust treated before sealing in.
Old 08-02-2023, 07:28 AM #26
I did learn my lesson years ago about using generic 120v migs. I happened upon my Miller at the local bar. The bartender had it and said it was broke and gave it to me. I gave him 90 for it after I fixed it and got the cart for it. I use gas and have the big bottle. The small bottle only lasts 45 minutes of welding.
Old 08-02-2023, 09:35 AM #27
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Isn't it night and day generic vs brand name with heavy duty cycles...
Old 08-02-2023, 01:05 PM #28
Old 08-30-2023, 09:35 AM #29
Kmurt's Avatar
Kmurt Kmurt is offline
Kmurt will become famous soon enough
Kmurt's Avatar
Originally Posted by MAD 69 View Post
I can't believe I'm still doing with this-i got the one side done for $1600 now the other side needs it. This is a bigger problem since the gas tank needs to be pulled. You see all these shows where guys restore 1932 Cars pulled out of junk yards but try repairing a 25 year old truck and it's a nitemare.
I wonder if I could rig something cheap, but safe I'm not going off-road in this or driving far, it's just for running around town and driving short distances. I have 290K miles and the engine sounds and performs as good as the day I bought it.
Hey I noticed you were in New Jersey. Back in July I had Garden State Auto Repair replace both of my rusted out rear upper shock mounts. They cut the old ones out and welded in the new OEM replacements that I bought and brought to them. The gas tank did not have to be removed either. They did a really good job and it only took them two days to do it. They also undercoated the rear of the 4runner with Woolwax so they should be protected for another 22+ years.
They charged $1800+ tax for all of it. Very pleased with the work.
2001 4Runner SR5 4x4
2019 4Runner TRD Offroad 4x4
Kmurt is offline   Reply With QuoteReply With Quote
Old 08-30-2023, 10:02 AM #30
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Which one as there are a few Garden State Auto Repair in NJ.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
can’t , mechanic , mount , shock , shocks
3rd gen upper rear shock mount rusted jimiv 3rd gen T4Rs 29 05-12-2021 09:32 AM
Rear Shock Mount Rusted Out Buckaroo 3rd gen T4Rs 21 04-06-2021 01:50 PM
HELP - Shock Assy. Stuck/Rusted to Frame Mount... mr_souc Engines / Suspension / Wheels / Tires / Audio / Accessories 2 11-28-2020 11:51 PM
Help! Top of Rear Shock Mount Rusted Away seoulstice 3rd gen T4Rs 6 02-23-2013 08:56 PM
Rusted Out Rear Drivers Side Upper Shock Mount Awdtsi42o Classic T4Rs 6 12-07-2011 05:23 PM
