Old 12-22-2021, 02:47 PM #1
cas5259 cas5259 is offline
cas5259 is on a distinguished road
Light Bar Install
After seeing what small light bars can do, plus almost nailing a deer on dark road, I decided to take the pinnacle of 90’s lighting technology to the modern age, hah. I didn’t want to put in a big honkin bar up top, so here’s what installing a rough country 20” dual row bar in the bumper looks like.
One note is that I will be using these as driving lights, so I wired it to come on with the high beams.
Measure twice, drill once. Those air holes make it tough to line up a good spot to use the supplied mounts. These are M8 rivnuts to match the supplied hardware.
Brackets bolted up solid. They came with rubber isolators, guessing to dampen vibration.
Quick test and confirming aim.
Trimmed bumper plastic to fit. Sanded the flat surfaces a bit with a die grinder and then hit it with a bit of propane torch to smooth it out. You can’t tell it was cut unless you really looked for it.
Bumper on. Looks good!
Wired up the battery side connections, relay mounted with the body ground.
High beams in non-DRL are negative switched. The wire in the middle is the one you want to tap into to switch the relay. I soldered to this wire because I was out of small gauge t-taps. Here’s a shot of testing the high beam function after depinning the supplied crappy switch.
Before.
After.
Fairly stealthy install.
cas5259 is offline   Reply With QuoteReply With Quote
Old 12-22-2021, 03:14 PM #2
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
That looks very nice.
Did you leave a provision to run the high beams with the light bar off? I find in some situations like certain snow nights I like the high beams alone. It's nice to have the option.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 12-22-2021, 04:05 PM #3
ledlow ledlow is offline
ledlow is on a distinguished road
Very clean install…good job.
ledlow is offline   Reply With QuoteReply With Quote
Old 12-22-2021, 04:51 PM #4
Yeah, I ordered an OEM fog light switch that I will hook up in series to control whether or not it comes on with the high beams, it just hasn’t arrived yet.
Old 12-23-2021, 06:21 PM #5
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
nice install...need to do that but on a fat lip....wonder if any write ups on that.
Its also good that you have it on switched power..i have seen several cars that are in a parking lot and have their light bar on, and no one in car.
also agree with Kanoe....there are many times I can not use one ( on other rigs) due to snow falling or thick fog
Old 12-23-2021, 08:28 PM #6
revox92's Avatar
revox92 revox92 is offline
revox92 is on a distinguished road
revox92's Avatar
Very neat installation! I'm going to show this to my neighbor for his incoming TR4 project. Still waiting for it to return from tire mounting and balancing.
2004 Toyota 4Runner SR5 4WD Auto
revox92 is offline   Reply With QuoteReply With Quote
Old 12-24-2021, 01:55 AM #7
thenightman's Avatar
thenightman thenightman is offline
Real Name: keith and jenny
thenightman will become famous soon enough
It's almost like they designed the front bumper to be perfect for a light bar. They look so good there.
Build thread
http://www.toyota-4runner.org/3rd-ge...ncemobile.html
Few dollars, and fewer sense
thenightman is offline   Reply With QuoteReply With Quote
Old 12-24-2021, 09:35 PM #8
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
I fit a Harbor Freight 14" bar behind the grille of my '02, just did some minor grinding behind the "slats" since it contacted the bar. I was able to utilize two existing holes so no drilling required.
Since my foglights were no good and already bypassed the DRLs I rewired the OEM foglight circuit to turn on only with the highbeams and use the stalk switch to turn the bar off, since the light bar is overkill for suburban driving and daytime flash-to-pass
Old 12-24-2021, 10:04 PM #9
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Sounds good. Got any photos?
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 12-24-2021, 11:17 PM #10
Real Name: 3 Bears
Real Name: 3 Bears
the upper grille above bumper or the lower section toward bottom of bumper between fog lights ?
thanks for adding pictures to original post
Old 12-25-2021, 11:46 AM #11
Yea let’s see some pics.
Old 12-25-2021, 08:01 PM #12
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Sorry, I couldn't find my imgur password/email info LOL.
I cut some predrilled/angled shelf brackets (just needed the straight sections) to situate the bar further in. The two innermost marks were other existing holes while the more outer ones were the bar's mounting spots.
Old 12-25-2021, 08:08 PM #13
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Open the images in a new tab to see the huge versions, should be able to see the cuts I made.
I cut out the solid spots behind the "T" emblem because I planned to install a LED pod behind it, not necessary with the bar.
Old 12-26-2021, 03:33 PM #14
Real Name: 3 Bears
Real Name: 3 Bears
looks good. what size light bar is that? I also see you put painters tape on grille but does not look like you did any cutting to grille, which I would like to avoid if possible
Old 12-26-2021, 05:49 PM #15
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
It's a 14" Harbor Freight Roadshock spot/flood, had a 20 or 25% off coupon at the time.
I had the tape on the grille just to mark the centerline and sides of the bar. I did have to trim some areas in the back of the grille where the bar was hitting, if I used longer brackets to mount it further in I probably wouldn't have to. I also unnecessarily cut off one of the center vertical bars directly below the "T", was for the pod I originally planned to use.
bar , bumper , here’s , high , supplied
Passenger Rear Turn signal quit working after light bar/ditch light install ewokfarmer 4th Gen T4Rs 1 01-11-2021 09:11 PM
Fog/AUX light install poleclimber63 3rd gen T4Rs 11 01-13-2019 01:12 PM
ABS Light after LED install... eddie4christ 3rd gen T4Rs 16 07-17-2018 06:39 AM
Fog Light Install 01sr54x4 3rd gen T4Rs 13 11-17-2009 08:15 AM
