Old 01-15-2022, 02:55 PM #1
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Manual transmission, stiff clutch
Easy fix?
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 01-16-2022, 03:31 AM #2
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Did it suddenly get stiff after being 'normal' forever, or ??
pluton is offline   Reply With QuoteReply With Quote
Old 01-20-2022, 11:30 AM #3
That's a good question, it's a vehicle that I went to see in a test drive situation but they were far worse problems than a stiff clutch
I've done a bunch of research in the meantime after posting the question and found several potential causes, including the pressure plate, master and slave cylinders, pedal spring and bushing.
Old 01-20-2022, 02:46 PM #4
Assuming the easy stuff is working, somebody probably put in and "HD" clutch without really needing it. Most of the HD pressure plates will about double the pedal force required. Nice when you need to hold power, not nice to drive in traffic. Of course, to fix that requires a new pressure plate...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-20-2022, 07:37 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Can't the master or slave cylinders be upgraded to reduce the stiff pressure plate feeling? As an option as well... Maybe not just trying to help think of another solution. :-)
Old 01-20-2022, 08:11 PM #6
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
They might have also taken out the squeaky OEM pedal spring and replaced it with a linear. This makes quite a noticeable difference in pushing effort.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 01-20-2022, 08:47 PM #7
Unlikely. If you decrease the bore size at the master (or opposite at the slave), it reduced throw at the clutch - meaning it might not release correctly.
Old 01-21-2022, 04:02 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Fair enough for me.. I was just trying to come up with a solution. :-)
Old 01-21-2022, 11:13 PM #9
Turns out it's just a bushing to cure a squeaky pedal shaft for me
clutch , easy , manual , stiff , transmission
Manual Swap Clutch Pedal and Clutch Master Cylinder VernySanders 3rd gen T4Rs 5 06-27-2020 11:21 PM
manual transmission - intermittent soft clutch pedal hiker2 3rd gen T4Rs 12 07-22-2018 07:54 PM
Manual Transmission Whine & Clutch Question (R150F) dtc81 3rd gen T4Rs 10 07-18-2018 09:17 PM
Manual Clutch Recomendations Twoods927 3rd gen T4Rs 12 01-20-2010 11:12 AM
stiff clutch on 96 4runner Roland 3rd gen T4Rs 2 10-23-2008 12:25 PM
