Old 02-03-2022, 09:25 PM #1
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Power antenna replacement
I know the factory part is like $135 from partsouq, but I found a universal power antenna at crutchfield for $70 with free shipping.
Made by RetroSound, has anybody installed PA-01 in a third gen?
How about any other, aftermarket power antenna?
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 02-03-2022, 09:47 PM #2
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I got a "reman" antenna from these guys - PNW 4Runner Connection - ??
Cost bout 75 bucks a couple years ago, but works great. I have bought a few things of Josh. He is a nice guy.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 02-04-2022, 03:36 PM #3
Sent them a message on FB last night... Awaiting a response
Thanks!
Old 02-04-2022, 05:10 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I just pull my power antenna modules out of the pick and pulls. Mostly they are good and you can use an aftermarket Martin them...
Old 02-04-2022, 05:31 PM #5
Whatever you do, keep it lubed with some dry graphite lube to avoid future problems. These days, I just don't use the antenna to keep it from breaking.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-04-2022, 07:17 PM #6
GFish GFish is offline
GFish is on a distinguished road
Is your unit bad or is the cable/gear strip broken? Basically, do you hear the motor going by the antenna does not go up and down?
If that’s the case, you can get by with a cheap antenna only. I just did this a few months ago and it only cost me about 10 bucks.
If your motor is bad, that’s a different story.
GFish is offline   Reply With QuoteReply With Quote
Old 02-04-2022, 09:06 PM #7
The antenna snapped off, the motor works fine - I hear it run when the radio powers on. I barely use it to be fair but I'd like to fix it.
Sent from my Pixel 4 XL using Tapatalk
Old 02-04-2022, 10:10 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Changing the antenna mast are easy to do. I done 2 so far.. You can do it by just need to remove the plastic inner fender. Best to replace those plastic grommets as they get really brittle.
Old 02-04-2022, 11:35 PM #9
fatherohenry's Avatar
fatherohenry fatherohenry is offline
Real Name: Mark KN6TZI
fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough
I've bought two power masts from TheAntennaSource.com, maybe $23 (each). Fast shipping, quality product, simple fix. They have plenty of other options too, if you're looking for something different.
'96 T4R SR5 | 4WD | Auto | 199 TBU | 268k+
fatherohenry is offline   Reply With QuoteReply With Quote
Old 02-28-2022, 07:16 PM #10
I bought one off Amazon and it was a piece of cake to install.
antenna , installed , pa-01 , power , retrosound
Power Antenna Replacement mpm19958 General Discussions 1 08-16-2019 11:44 PM
Replacing head unit: 3 antenna input question & power antenna replacement question Rancho5 3rd gen T4Rs 14 08-24-2018 06:51 PM
Power antenna mast replacement Lunarphase 3rd gen T4Rs 0 02-07-2015 07:50 PM
power antenna replacement Crashnrondo 3rd gen T4Rs 4 05-22-2012 12:14 AM
power antenna replacement? Chadman 3rd gen T4Rs 7 12-29-2010 01:29 PM
