Old 02-16-2022, 09:11 AM #16
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by nathanroyse View Post
So, this is kinda weird to say this, and I never thought I’d be mad at something for working… but I got home from work today and plugged the old actuator back in and the doors are working perfectly. Do I just leave it alone and forget about it and risk it starting to do the same thing again? Or keep hunting for this mysterious “pinched wire” that I’m just not seeing…
Up to you. Glad it's currently working..
Old 05-18-2022, 10:47 PM #17
nathanroyse nathanroyse is offline
nathanroyse is on a distinguished road
Bringing this back because the doors were working perfectly for the last couple months… but now it’s back. I think I can provide more information this time in order to possibly narrow down the search. Everything was good until I pressure washed my engine bay while washing the rest of the car. I obviously didn’t get close to any electronics but close enough to every to get all of the mud and dirt out of the engine. Is there anything door lock related that could be causing this in the engine bay? Also, if I repeatedly press the unlock button on either the key or the remote, the doors will lock and the button will stop working until I press lock then press unlock again to unlock everything. Where can I find wiring diagrams for the door locks?
nathanroyse is offline   Reply With QuoteReply With Quote
Old 05-19-2022, 08:42 AM #18
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
So moisture makes it act up. That to me really sounds like a wire issue or being cracked insulation and shorting against ground. Etc.
File Type: pdf Back_Door_Lock_Control_Without_Door_Lock_Control_2000.pdf (39.0 KB, 2 views)
Old 05-19-2022, 02:08 PM #19
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
when my doors did this, it ended up being the dome light switch in the door jam.
Old 05-19-2022, 07:33 PM #20
Can you explain a little more what it was and how you fixed it so I can see if that’s my problem too? Thank you
Old 05-19-2022, 10:10 PM #21
Real Name: 3 Bears
Real Name: 3 Bears
Sure.....first I noticed one day that my car was unlocked....when and where I lived at the time I always locked it. then one day I was out by my car and noticed the doors were unlocking and locking...
I posted on this forum the situation....and some one said....how is your door jam switch working and was told that a bad switch can fool the computer thinking your door is either open or closed even if it is closed it might signal that it is open......I thought .....well sometimes my dome light does not come on. So I went out , opened the door and pushed the door jam ( dome light or as others call it a courtesy light switch) switch repeatedly.....sometimes the light came on and other times not. I then tested all the switches....and only the driver side did this ( the one most often used) so I thought ...well that is cheap and easy and its obviously not working correct anyway so worth a shot.... got a cheap aftermarket replacement that was available in town....replaced it and my door lock issue problem went away as well..so then I ordered a new oem one and put in.
fast forward about 5 years and 4runner #3. Dome light would work sometimes....I still had the aftermarket one in my stash of parts, put it in...solved dome light issue....that one never displayed any locking issues to me....but the person I bought it from said that sometimes the door locks would not work if using the remote. So he quit using the remote. Since putting in the new switch shortly after I bought it and new battery in remote.....i have been using the remote now for nearly a year ( in one month will be a year) with no issues. It might have all been a coincidence on this particular 4runner
anyway....its just a thought
Old 05-20-2022, 01:29 PM #22
Taylor20's Avatar
Taylor20 Taylor20 is offline
Taylor20 will become famous soon enough Taylor20 will become famous soon enough
Taylor20's Avatar
It could also be your integration relay attached to the fuse box behind the driver dash panel
02 Sport
Toytec Boss/LJ - TRD Pro & 255's - TBU - 4:30's - Elocker
4xI - AED - Savage
Taylor20 is offline   Reply With QuoteReply With Quote
button , door , lock , started , unlock
Power locks keep locking themselves when it rains ColoradoMTNlivin 3rd gen T4Rs 5 12-18-2016 05:19 PM
question about hitch locks and trailer door locks wadeanderson 4th Gen T4Rs 2 11-11-2014 11:55 PM
Door Locks LarryB 3rd gen T4Rs 15 08-23-2014 09:59 PM
Power locks won't unlock (but locking works) abw73 3rd gen T4Rs 5 11-18-2011 05:39 PM
wireless door lock enable when started? Limited99 3rd gen T4Rs 0 10-14-2009 09:12 AM
