Old 03-22-2022, 04:19 PM #1
ivopivo ivopivo is offline
ivopivo is on a distinguished road
Car moves forward when in neutral…
Just noticed it today. No it’s not like when in drive it just has a little power and moves even up a small hill. Trans f*ked?
ivopivo is offline   Reply With QuoteReply With Quote
Old 03-22-2022, 04:35 PM #2
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
That would be a failed torque converter if automatic transmission
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 03-22-2022, 06:19 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Your shift linkage is probably out of adjustment. Chock your wheels/set parking brake, shift transmission into neutral, loosen the nut on the linkage at the transmission shift lever, move the lever one click out then one click back (putting it out of neutral then back to neutral), then tighten the nut. If that doesn’t fix your issue then you have a problem with the manual valve in the transmission.
A failed torque converter will not affect gear selection.
Old 03-22-2022, 08:38 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
These are all symptoms of a TC issue:
Is your idle possibility to high? Mostly if the torque convertor is bad it will Stall at a stop sign or light because it's at stuck in locked position. Other Symptoms is noise coming out of it and if it got real hot the internal fins will warp and it will act like brakes are stuck on because the fluid can flow as effectively as it supposed to from the heat damage.
Old 03-22-2022, 08:50 PM #5
Real Name: Patrick
Real Name: Patrick
Am I missing something? Didn’t OP say he’s in neutral and the vehicle is moving under power?
Old 03-22-2022, 10:31 PM #6
Correct. Other gears all work as they should. It’s also intermittent… in 4-5 starts today it happened 2x. The other 2-3 it was actually neutral not moving at all.
Old 03-23-2022, 01:18 AM #7
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Easiest thing to check is the shift linkage. You'll know right away if it is the problem.
326WHP 347TQ
Old 03-23-2022, 10:25 AM #8
Is there a writeup how to check this?
Old 03-23-2022, 11:29 AM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Most likely it's linkage. I just explained what you see when torque convertor bad. Which I don't think it is at all. Maybe I should have been clearer. Thanks to @badluck for pointing out I didn't clarify. Will correct the post.
Old 03-23-2022, 05:06 PM #10
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Go under car where the shifter is, you can see the lever coming out of the black rubber boot on the right of pic (the front boot) and links with a nut to the rod that moves the transmission shift lever on the actual transmission. You may want to make a witness mark for that nut (right side of pic) so you know where it was. Loosen it and do what Bad Luck said above. If the lever out of the boot is all floppy then you could replace the shifter bushings. https://www.youtube.com/watch?v=gCHSRcq-LP8
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 03-24-2022, 08:57 AM #11
Thanks I actually cane across that vid while searching around yesterday. Will try it asap
Old 03-24-2022, 04:02 PM #12
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
How loose if the shifter handle? Might be a great time to replace the rod bushing so the linkage is 100% tight. Before the new bushings, my shifter engaged pretty sloppy.
2000 4Runner Limited 4x4 V6
car , hill , moves , small , trans
Upper shock moves? TinBucket 3rd gen T4Rs 1 07-10-2017 12:47 PM
Liftgate moves in and out when latched MudMud 3rd gen T4Rs 2 02-24-2017 09:01 PM
Rear axle moves kolelt 3rd gen T4Rs 16 03-16-2016 10:54 AM
Truck only moves in 4-Lo Sullijm1 Classic T4Rs 2 03-22-2015 04:06 PM
99 - 4Runner Drives Forward in Neutral ?!?! Post strawberry milkshake issues... SJChiz Problems & Warranty Issues 1 09-03-2012 12:14 AM
