Old 04-07-2022, 06:48 PM #1
ir0nma1den ir0nma1den is offline
ir0nma1den is on a distinguished road
Exclamation Leaking red fluid bad, can I drive to a mechanic?
My 4runner has sat for 3 days, just drove it and noticed some smoke coming from the the air intake in front of the windshield. Then noticed my temp gauge getting hotter. Pulled over to see all this. Can I drive it 3 miles or should I tow?
ir0nma1den is offline   Reply With QuoteReply With Quote
Old 04-07-2022, 06:58 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Do not push the engine temp into H. If you think you can keep water in it and get it there. That's up to you.
I'd verify that antifreeze. Isn't going anywhere else and just leaking to the ground.
Should be able to fill it with water. You sure you just not a cracked or busted hose. Or the heater valve didn't snap?
Old 04-07-2022, 07:05 PM #3
Not sure how to verify it’s antifreeze. No engine codes yet. Never hit red on the temp gauge but got close. Judging by where the insulation melted and the fact there is red fluid at the top seems to me like a leak from a line up top.
Old 04-07-2022, 07:17 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I would check all fluids make sure all is well and try to isolate that leak. Those heater valves can Crack abs snap.
Once the engine is ice cold. You can carefully open the radiator cap and check the antifreeze.
Do not touch a radiator cap if any heat is left to the engine at all.
The 3 red fluids would be antifreeze, Power steering along with transmission fluid.
Being those lines that are all coolant lines to the rear heater and the heater core. I suspect the leak in thst general area up top there.
Old 04-07-2022, 07:53 PM #5
Well, I’m seriously thinking an animal was nesting in here
dice application
Old 04-07-2022, 08:02 PM #6
Case solved. Can’t even believe it
upload
Old 04-07-2022, 08:18 PM #7
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Funny, I saw that little bugger is one of the first pictures but thought that was some more insulation that worked it's way down
Still alive? Free pet if so!
Old 04-08-2022, 11:22 AM #8
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Rodent damage can be a disaster to deal with. Once you remove all that insulation double check the wires in that area to make sure they weren't gnawed on. Squirrels seem to go more for rubber houses, and mice/rats prefer wiring. Good luck!
Old 04-08-2022, 01:37 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Glad you found it. It'd truly amazing how much damage those critters can do. It's one of the reasons I keep cats around.
Old 04-08-2022, 01:37 PM #10
Looks like that was one of the throttle body coolant lines. Don't drive it until you can replace that line.
Probably time to just pull off the hood insulation...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
drive , gauge , hotter , noticed , temp
New to me 4th gen (07) Automatic. Mechanic said not to replace trans fluid? Quiero 4th Gen T4Rs 4 10-18-2018 09:47 AM
Fluid Leaking chris2879 4th Gen T4Rs 3 06-20-2012 11:27 AM
Leaking Trans fluid... combatmedic Classic T4Rs 19 03-17-2012 07:05 PM
Leaking (Tranny Fluid?) dhelsdon Classic T4Rs 3 05-12-2011 01:39 PM
Blake fluid leaking Lineman Maintenance/Detailing 2 04-23-2011 09:50 PM
