Old 04-14-2022, 11:02 PM #1
schmauster schmauster is offline
schmauster is on a distinguished road
Just paired keyfob to 4runner, now it doesnt work!
Hey guys, I Just got some new remotes for my 2000 4runner SR5. I paired a new remote and it accepted it. I was able to lock and unlock my doors once i got out of the car but after about 5 seconds they didnt work anymore.
Maybe the alarm system has a bad connection?
I also never heard a chirp or beep but the buzzer is hooked up on the passenger side
Thanks
schmauster is offline   Reply With QuoteReply With Quote
Old 04-15-2022, 12:00 PM #2
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
Thanks
Do you have a PDF of owner's guide for the Viper 3200 system? It has programming info and troubleshooting for the system in a 2000 SR5, the same model that I have. I can send it to you in a private message if you like.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 04-17-2022, 12:04 AM #3
Thank you !! Ill let you know if it works out!
Old 04-18-2022, 12:25 AM #4
revox92's Avatar
revox92 revox92 is offline
revox92 is on a distinguished road
revox92's Avatar
I'll PM you if my friend needs that owner's guide. He recently got a new fob and it sometimes doesn't work. The 4Runner is in the shop for the new brake pads and toyo tires plus the alignment.
2004 Toyota 4Runner SR5 4WD Auto
revox92 is offline   Reply With QuoteReply With Quote
Old 04-24-2022, 08:38 PM #5
No progress yet but i suspect the fuse block under the hood may be the issue.
I disassembled the body ECU and reflowed the solder joints at the relays for the doors, put non conductive grease on quite a few things while i was in there.
My multimeter just stopped working so i had to call it till another one shows up.
Im going to clean the ground for "G202" I believe under the dash its supposed to be for the alarm. Then check resistances at powers & grounds... and go from there. Likely ill be grabbing an under hood fuse block online and disassemble/fix it up
I still cant find the actual alarm box. I opened up the back door, re-greased the window gears while i was in there... Took a look under the front seats. It must be under the dash but i dont see anything obvious.
Old 04-25-2022, 08:54 PM #6
So apparently my multimeter got wet. I dried it out and its ok now.
So the body ecu seems to be the culprit.
Heres what i did..
Hit the locks a bunch of times till it got slow
Tested voltages at both sides of the MBX5 fuse or whatever its called under the hood
Voltages were still good.
Hit the locks a bunch more..
Checked voltages at the connector for the driver window control and ive only got 11.38 volts at the red and red/white wires.
Checked supply voltage at the body ECU... Battery voltage...
Looks like the relay in the body ecu is the culprit since i had it all apart a few days ago and saw no corrosion.
Im going to try to find the relays and change them out in the body ECU and go from there.
Any help is appreciated!
Old 04-26-2022, 01:23 AM #7
FUJITSU FBR51ND10-W1 COMPACT POWER RELAY, 35A @ 14V SWITCHING, 10V COIL, 5 PCS | eBay
Old 04-26-2022, 03:05 PM #8
Found this crusty fuse on my travels
Just paired keyfob to 4runner, now it doesnt work!-20220421_124742-jpg
4runner , car , connection , paired , work
4WD Hi doesnt work dierte 3rd gen T4Rs 7 11-25-2014 03:10 PM
95 4runner 4x4 6 cylinder Automatic - O/D doesnt work Plus Etc. rhd91integra Classic T4Rs 9 07-25-2012 07:06 PM
4WD Doesnt Work spoiler900 3rd gen T4Rs 8 12-28-2011 11:39 AM
JBL Synthesis AM Doesnt Work imdav2u 4th Gen T4Rs 3 10-18-2009 03:11 PM
4wd doesnt work? Mike415 3rd gen T4Rs 5 09-05-2006 01:09 AM
