Old 04-19-2022, 06:00 PM #1
5VZ-FE's Avatar
5VZ-FE 5VZ-FE is offline
5VZ-FE will become famous soon enough 5VZ-FE will become famous soon enough
5VZ-FE's Avatar
Grounding to parking brake
I’m sure it’s possible to ground (a 12v usb outlet which I have mounted in the rear ashtray slot) to the parking brake but I don’t know where. There’s an insulator between one of the bolts I looked at and the body…
Anyone know which bolt I should use?
‘98 T100 SR5 4X4 5spd (sold)
‘99 4Runner SR5 4x4 5spd E-Locker Unicorn
5VZ-FE is offline   Reply With QuoteReply With Quote
Old 04-19-2022, 08:35 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Why not use the one of the 4 parking bolts on the bracket? These bolts go through the bracket and into the body so they should work for you..
Old 04-19-2022, 09:21 PM #3
5VZ-FE's Avatar
5VZ-FE's Avatar
Originally Posted by brillo_76 View Post
Why not use the one of the 4 parking bolts on thr bracket? These bolts go through the bracket and into the body so they should work for you..
Thank you. I ended up using the screw that holds on the parking brake switch since I didn't have a big enough ring terminal for the bolts.
Old 04-19-2022, 09:26 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
That works too as its all fairly well grounded. :-) The eyelet and the insulation looks good.. Blends in well. Good Job.
brake , grounding , insulator , parking , there’s
Parking Brake / Emergency Brake Question Woz1976-MT 5th gen T4Rs 5 04-21-2018 05:52 PM
Parking brake not holding after rear brake job 4OYOTER 5th gen T4Rs 6 10-06-2017 11:04 PM
Parking Brake transfer cable inside brake drum JBDaddy 3rd gen T4Rs 8 03-14-2017 03:09 PM
Is driving 07 T4R with the parking brake shoes on, only hurting the parking brake’s jow 4th Gen T4Rs 2 05-15-2013 02:31 PM
Driving while parking-brake is on brake zak4runner Maintenance/Detailing 9 04-07-2007 08:24 AM
