Old 03-24-2023, 02:41 PM #286
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Next up on the to-do list is the sway bar end links up front. I've had a set of Moog end links sitting in my tool box for two years. Going to pair them with a fresh set of poly bushings from Energy suspension. These end links are greaseable, too, so that's cool. Might try knocking out the sway bar bushings at the same time as well. Also energy suspension poly bushings.
Old 03-24-2023, 02:51 PM #287
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I use moog parts and get yelled at.... Sorry, I want grease fittings
Old 03-24-2023, 09:42 PM #288
JoeT4R's Avatar
JoeT4R's Avatar
They're not bad parts but they're certainly not OEM. The greasable zerks are a plus though, I agree with you there. Which reminds me that I need to grease my outer tie rod ends.
Sent from my SM-S908U using Tapatalk
Old 03-25-2023, 03:07 PM #289
JoeT4R's Avatar
JoeT4R's Avatar
Just a rainy day. Snapped on my S22 Ultra.
Old 03-26-2023, 02:20 PM #290
JoeT4R's Avatar
JoeT4R's Avatar
Air filter replacement. Also greased outer tie rod ends.
Date: 3/26/23
Mileage: 324,195
Old 03-29-2023, 06:50 AM #291
JoeT4R's Avatar
JoeT4R's Avatar
LONG overdue brake pads and rotors job. Removed my OEM pads and rotors. They lasted a little more than 72K miles, which is definitely a lot. The pads had some life left on them but not much. The rotors were toast, had been for a long time now. Like terribly warped and violently shaking when applying the brakes.
I ended up throwing in Hawk LTS pads (p/n HB315 Y.669) and store brand rotors from Advance Auto (Carquest Wearever p/n YH145137). So far the combination of the two is beautiful, as I'm able to gently apply the brakes and come to a smooth and quiet stop. The job itself was easy and I did it in a friend's driveway in about 2 hours total, but it took longer due to having to take breaks and run an errand in between.
Fortunately a friend of mine has a bench grinder, so while I was removing hardware and pins and bolts, he was cleaning them up on this bench grinder. It made everything look literally brand new. I was so impressed that I only remembered to take pictures of the sliding pins that hold the pads in place. Wish I would've snapped some pics of the caliper bolts. They look beautiful when all cleaned up.
I'm super happy I finally got this job done as it was long overdue. I feel like my truck is basically new again.
Date: 3/28/23
Mileage: 324,268
Old pads, super worn down.
20230328_152806
OEM rotors with warpage.
20230328_152324
Sliding pins before and after cleaning with angle grinder.
20230328_155535
New meaty Hawk LTS pads installed!!
20230328_170823
Part number for pads in case anyone is interested.
20230328_172932
Old pads from other side of truck.
20230328_175717
And finally, mileage.
20230328_184528
Old 03-30-2023, 07:54 PM #292
JoeT4R's Avatar
JoeT4R's Avatar
Most up to date side profile, with the new rear springs and shocks installed.
Old 04-06-2023, 04:57 AM #293
JoeT4R's Avatar
JoeT4R's Avatar
Bled the brake system yesterday. Did it with the key turned to accessory. The rears were unable to be bled. Passenger rear bleeder screw was clogged despite using a needle/pick tools to try cleaning it out. So I'm going to buy a replacement bleeder screw for it soon and knock that out.
Driver rear bleeder screw was rusted like crazy so I imagine I'll have to get some type of extractor on it and replace that one as well. Front passenger and driver sides were both easy. The fluid was straight up black. But I finally got clear fluid coming out of the lines.
Used a syringe to remove a bunch from the master cylinder and replaced with fresh fluid. Overall there has been no change in the feeling of my brake pedal. I'll give another update once I bleed the rear system.
Date: 4/5/23
Mileage: 324,509
Old 04-06-2023, 10:12 AM #294
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
This is why they make bleeder covers...;)
Old 04-06-2023, 10:18 AM #295
JoeT4R's Avatar
JoeT4R's Avatar
I had no idea. It's no biggie, I'll get some new bleeder screws and go from there. I'm happy to get at least the fronts done. That fluid was darrrrrrk!
Old 04-06-2023, 10:54 AM #296
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Speed bleeders stainless steel.. :]
Old 04-07-2023, 04:35 PM #297
JoeT4R's Avatar
JoeT4R's Avatar
Found an old picture that was hand drawn by an old friends family member. Great memory!
Old 04-17-2023, 12:17 PM #298
JoeT4R's Avatar
JoeT4R's Avatar
Reached out to the p/o of my truck, hadn't spoken to her since I bought the truck a little over 10 years ago. She sent me a photo of the truck when it was bone stock and I thought it would be cool to post up a baby photo.
Pretty wild to see it like this. I somewhat miss the simplicity of it being stock and everything. So beautiful!
Old 04-17-2023, 01:30 PM #299
Speedy's Avatar
Speedy Speedy is offline
Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough
Speedy's Avatar
Looks just like mine did.
Speedy is offline   Reply With QuoteReply With Quote
Old 04-17-2023, 01:44 PM #300
JoeT4R's Avatar
JoeT4R's Avatar
I do miss it, but I wouldn't go through all the work and costs to put it back to stock. Sometimes I wonder though... lol.
build , joet4r’s , reserved , sr5 , thread
415Yota’s Build T4topher 3rd gen T4Rs 346 08-21-2023 07:17 AM
SURF RUNNER 2.0 Build, Maintenance & Modification: 2001 Stellar Blue Limited 4WD SURF RUNNER 3rd gen T4Rs 41 10-27-2020 10:01 AM
I’m pretty sure it’s dead Jim. Rear drivers lower link mount broke off frame. 19963.4lsr5 3rd gen T4Rs 16 09-12-2020 11:41 AM
Doc's maintenance/build thread Cow_doc.308 3rd gen T4Rs 8 09-17-2016 12:08 AM
v3's maintenance/build thread v3bahumut 3rd gen T4Rs 7 04-27-2014 12:14 PM
