Originally Posted by nissanh
You can check the current drop across any fuse as well. It should not be even a 1 mA if current is not flowing.
You mean with the fuse out check the socket with an Amp meter? Because you can't check for current flow unless you open the circuit and become part of it. [ well with a inductive Amp meter you can but you have to isolate the wire as it measures the magnetic field]
You can check for Voltage across a fuse as well as connectivity. But as I far as I know, you can't check amperage.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
