05-29-2022, 12:01 AM
Frank
I posted a version of this over at Mud, and may keep that up if it makes sense, but realizing there are way more of y’all here than over there for the T4R. I’m also learning this platform, apologies in advance for weird photo placements!
With the 80 off to a new home soon, it was time to pick up another daily. While I loved having the space and unmatched capability, I missed the smaller dimensions of the 4Runner and wanted a little more engagement in my drive. Was originally looking for a 2nd gen 22RE with a 5 speed, but found this one instead up in the Bay Area. 1997 3rd gen 5 speed with 4WD, Lavender Steel. Geez what a wussy name for a great color. Kids had named it Frank before I even got it home.
First time I’ve done a fly and buy. I reached a deal with the seller around 11am, was on the plane by 2pm, on the drive home by 4pm, and home again by 11pm. Busy day.
Radiator is new Denso (China) and filled with Toyota red. Clutch is relatively new, has a quality respray that color matches excellent with the door jambs, done mainly to correct for peeling clear. They painted the bumpers too, though, so may fix that sometime. 4WD engages smoothly, new front brakes, all else is in good working order. Does have a few needs, particularly upper and lower ball joints (baseline), shocks are really bad and probably original, and it has a minor steering wheel shake at around 60-70 mph. Taking out the ball joints first, hoping that does it but we’ll see. 168K miles.
Interior in good condition, typical wear and a small tear on the outer bolster on the driver’s side seat. I was able to find the covers and non-sport seat pad on Amayama, so those are on order. Replaced aftermarket stereo with my favorite single DIN Toyota head unit out of a Camry with a Crux BT adapter, my third one of those.
Some photos for your perusal…
05-29-2022, 12:52 AM
Real Name: Keith
Real Name: Keith
You are lucky to have obtained a 4 cylinder in good shape. That configuration, eg 4WD/3VZ-E/5-speed/no sunroof was my preference when I was shopping for a 3rd Gen 4R in 2013. 7-8 months of daily searching the CL and Autotrader postings yielded only a few trashed 4 cyl trucks, so I settled for a 6-cyl version.
05-29-2022, 01:30 AM
Thanks and agreed! I found a few roached-out 4 cyl trucks as well but none this well kept. Came close to getting a project 95 22RE 4WD 5 speed with a broken timing chain, but it was up and gone within a few days and too far from home, and no idea what the bottom end looked like.
05-30-2022, 12:32 AM
Upper and lower ball joints replaced, took a day and a half after screwing up one of the ball joints with the press (user idiocy) and having to replace the passenger side tie rod due to messed up threads (not my fault). Also had a bolt head shear off in the knuckle arm, the one that holds the brake line in place between the soft line and the hard line to the caliper. That was a 2 second job that ate up probably 2 hours of faffing around with a drill, tap, chisels, and all other manner of punches, liquid, and fire persuasion. Finally just tapped a new smaller hole and went with it. Also managed to replace one of the wheel lug studs, good as new.
All in it was an easy job, but it was all the other garbage that made it awful. On top of that, Amayama cancelled my order as none of the parts are available. Which isn’t a surprise, really. Rough day but it’s done, taking it down for an alignment tomorrow.
Next up - Bilstein 5100s on the way.
05-30-2022, 09:17 PM
Great story, I'll enjoy following along. Nice looking truck!
Sounds like we have had many of the same adventures.
~Jason
05-30-2022, 09:30 PM
you got lucky, amazing condition looks like, hope you have a great experience with your 4runner.
i'll be rooting for ya, good luck!
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
05-31-2022, 08:11 AM
3RZ 4WD -- the ultimate 4Runner configuration! Congrats!
Make sure to take a look at valve adjustment... V6 guys can get away with neglecting it but the valves usually tighten on the 3RZ over time. I've touched mine up a few times and it's nearing 300k
05-31-2022, 09:20 AM
I need to add to the list. Thanks for the reminder! Never did one on the V6, but have on my FJ40 and 2002. The whole shim-over-bucket thing seems like a pain, to be honest. Thank goodness for Tim’s videos!
Alignment done, fixing up the radio backlight with some 3mm incandescent bulbs since one was burnt out. Re-flowed solder on the power contacts in the clock and the 4 larger diodes (I think?) on the board, which hopefully is the fix for the LCD fading out a bit. Tested good last night.
RockAuto cart is filling up with a few other odds and ends - replacement headlight bulbs, end links, windshield wipers, the important stuff. FZJ80 heads off to its new home today.
06-01-2022, 11:10 PM
Clock backlight fix worked, holding nicely the last 2 days driving to and from work. Shocks and front top mounts have arrived for install this weekend. Other parts on order to arrive next week, end links, headlight bulbs, wipers, etc. Has a funky stink though that I need to eradicate from the interior. Nothing mechanical, just smelly.
Fun truck to drive, averaging about 20 mpg in traffic and can prob do better. Big relief!
06-01-2022, 11:50 PM
Real Name: C8H18 Mike
Mine stunk like gear oil. The rubber shifter boot under the cloth/leather shifter cover was not properly seated on the shift rod. A 2 second fix got rid of the stank.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
06-02-2022, 08:00 PM
13WLs from the junkyard, the rest of the parts are OEM on the way from Claremont Toyota.
06-02-2022, 09:20 PM
Not Toyota but I got an entire 13WL kit with complete calipers, pads and drilled & sotted rotors from Callahan for $220, no core charge
06-02-2022, 11:16 PM
That’s a deal. I paid $80 for the junkyard calipers total, and another $300 for OEM parts including a rebuild kit, rotors, brake pads, and shims, shipped w tax. I did this with my last 3rd gen, wasn’t going to do it with this one until it was needed but already hating on the stock brakes. Need to check the rears too at some point. Brake pads got $$, geez.
Installed some eBay tweeters and redid the backlights on the LCD. Sounds better but need to do the LCD backlights AGAIN because one of the little green doodads didn’t get pushed on all the way, and is causing that light to shine slightly dimmer than the other one… could probably do that with my eyes closed at this point.
06-02-2022, 11:27 PM
Some better photos from the dinner run.
06-05-2022, 10:02 AM
Busy day yesterday. Started with a trip out to Ontario to try my luck at picking up seats at yet another pick and pull. This time got lucky and scored a good condition passenger seat that matches the upholstery, a good looking OEM rear bumper that needs some paint correction, a rear windshield wiper arm, and a few other odds and ends. It looks like these seats came in the 1996-1998 non-sport GRAY color way, I’ll keep this in a saved search and check LKQ every few days to see when another one comes up locally.
Next was to tackle shocks. I was able to install all 4 corners, but this truck wants to fight me every step of the way. Rusty fasteners slow work to a crawl. I pulled the driver’s side shock and spring assembly, loaded up the springs to remove the top hat, but the top nut was rusted on so badly that I ended up using the Dremel on the nut and shaft. Passenger side came off ok. This was a bad sign for the rears.
The rear shock mount was designed by a masochist, which is probably why these were never changed. The washers were rusted out flakes of their former selves, and I had to bathe the top nut in PB to get it to finally, thankfully, move on each side. I mopped up the pool of PB before getting up there with the 14mm, and used a pipe wrench to keep the top half of the old shock from turning. There’s just no room to get good torque on that nut, but made it work eventually.
Test drive was great, the truck doesn’t wallow all over the place like it did before. Steering wheel shake is still present at higher speeds, I have the steering rack bushing kit here for install probably later today.
