Old 06-20-2022, 02:02 PM #16
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by jharri7140 View Post
I will have to get around to compression testing it, interesting thing is the oil has no signs of water in it.
Could just be a microscopic mist and is burning up.. You can see that in the spark plugs mostly too.. :-)
Old 06-20-2022, 02:30 PM #17
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
You would only see coolant in the oil if the head cracked or the head gasket failed between a coolant passageway and oil passageway. Head gaskets typically fail between the cylinder bore and coolant passageway or between cylinder bores.
Old 06-21-2022, 10:23 AM #18
jharri7140 jharri7140 is offline
jharri7140 is on a distinguished road
Yeah my conclusion was it is just leaking strictly into the cylinder. Judging by how much coolant I am losing my thought is it is a fairly small leak. The effects I am seeing from it is sometimes causing a cylinder misfire at idle, as well as a slight decrease in mpg. So for now I am going to just let it be and watch the coolant levels.
jharri7140 is offline   Reply With QuoteReply With Quote
Old 06-21-2022, 11:31 AM #19
Real Name: Patrick
Real Name: Patrick
If you let it like that for too long it can corrode the block and then you will need to have the engine resurfaced or get a new engine.
Old 06-21-2022, 03:17 PM #20
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Blue Devil?
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 06-21-2022, 03:40 PM #21
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by octanejunkie View Post
Blue Devil?
Very bad idea to use any kind of stop leak in an engine. Honestly, does more damage then good
Old 06-21-2022, 04:23 PM #22
Real Name: Patrick
Real Name: Patrick
Blue Devil?
I would never recommend any of the head gasket repair additives unless you have no plan on reusing the engine (as in you are swapping the engine at a later time and need to buy some time). Those additives can do some weird stuff to the coolant passageways/thermostat/water pump.
Old 06-21-2022, 06:45 PM #23
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
Blue Devil?
I'd suggest Holt's Radweld or genuine Subaru conditioner if going this route. It's different and less harmful than most others.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 06-22-2022, 01:24 PM #24
Read up on Subaru Conditioner, seems the factory recommends it as an coolant additive on the regular to solve for a ln endemic issue - head gasket issues
Old 06-22-2022, 02:16 PM #25
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Interesting. If it doesn't clog up the water jackets etc. It's probably a great product for a temporary fix. Till it can be fixed properly. Our at least buy you time to get all the parts you need. Save up the money for the repair.
Being it's cast block to aluminum heads its only a matter of time till the head gaskets fail. As the metals heat up and expand and extract at different rates.
Old 06-27-2022, 11:16 AM #26
Older head gasket sealants were very bad about clogging thermostats, water jackets, etc. I spent a while extensively researching results from different sealant products. Based off the severity of my head gasket leak it was minor compared to leaks other people had been able to solve using head gasket sealant. So I made the gamble and bought some K-Seal ultimate and threw it in, making sure to follow the proper procedure for the sealant. Luckily for me it was a success and sealed the leak up, now begs the question of how long I have till it opens back up again, or if it opens back up even worse.
Old 06-27-2022, 02:31 PM #27
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I did find out that the Subaru head gasket head gasket conditioner is just rebranded bar leaks so keep this in mind..:-)
Old 06-27-2022, 03:23 PM #28
I don't want to make waves with you, Jon. I have very much respect for your knowledge and experience. Please keep this in mind.
The genuine Subaru coolant conditioner is not the same as Bar's Leaks products. It may share some similarities, but the formulation is different, and is much less likely to cause clogging of a healthy cooling system.
Genuine Subaru coolant conditioner is manufactured in England by Holt's, and is the same as their product Radweld. It even says so on the bottle.
There has been no credible evidence that I have seen to support the notion that it causes any clogging issues with engines, radiators or heater cores when used properly.
Here's a thread from a VW Vanagon forum (my '87 Westfalia is my other hobby vehicle) that started out blasting the product but later reversed the position contending that it is not harmful. The author is a very well respected engine builder within the VW platform. Please read all of the posts before rendering your opinion.
thesamba.com - Thread discussing Subaru coolant conditioner
_________
Old 06-27-2022, 09:10 PM #29
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Oh no problem with waves.. :-) I got that information from a mechanic.
here is a link: Please Wait... | Cloudflare
Its all very similar. The car mfg did this to get the engines past their warranty times. Its bad engine designs causing most of it. The head gaskets are failing causing the leaks.. :-(
In our case, its from the cast block and aluminum heads. Heating and cooling at different rates. I forget how many revisions toyota did on these head gaskets to make them better. (like 5 or 9 )
I personally stay away from the coolant leak sealants myself.
Plus folks can do as they wish..Its their rigs. :-)
fueling , idle , issue , misfire , rough
Really, really weird misfire problem importman 4th Gen T4Rs 38 05-01-2023 12:04 PM
Update on Weird misfire problem importman 4th Gen T4Rs 9 05-19-2020 07:12 PM
1997 4runner, 3.4l: idle speed too low, engine stalls at idle werminghausen 3rd gen T4Rs 11 09-01-2015 01:03 AM
V8 Misfire at idle 4RunnerV8 4th Gen T4Rs 27 03-03-2014 01:55 PM
Random misfire at idle only Rhouse 3rd gen T4Rs 4 05-28-2013 12:19 PM
