Originally Posted by ledzep41
In the original post I went through they why. It was because the previous axle housing was bent due to some rough riding.
You bent your axle housing and didn't replace the axle shafts and 3rd member??? No wonder you trashed your transfer case. [ sorry I missed that and when using tap talk is limited ]
My guess is your damaged all of it when you bent the axle housing. And drove around without verifiying all the other components were good in the 3rd member.. Over stressed and damaged the 3rd member. With all the abuse it broke the transfer case.
The FSM shows you how to verify and check a 3rd member along with your transfer.
So you can replace the damaged components with known good parts or rebuild what you got.
Rough riding is an understatement. :/
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
