06-20-2022, 12:40 AM
#16
Real Name: Patrick
Real Name: Patrick
Originally Posted by T4Rscott
The AC button lights up and is not flashing. I have not tried the bypass while running, only to actuate the magnet, which works. Would assume it would give cold air.
I’m going to try to run a bypass from the input for the original clutch to a newer unit and see if that makes any difference. If it doesn’t, I’m going to look into replacing the expansion valve.
I have even gone to the extent of replacing the IAC and TPS to rule that out.
The expansion valve has nothing to do with your compressor clutch not engaging at idle
06-20-2022, 06:36 AM
#17
I agree with Bad Luck, the expansion valve has nothing to do with it.
You already proved the clutch is good by connecting it to a 12 volt source, so rule out the clutch, problem sounds electrical. Look at the source of voltage- what controls the system to make the compressor clutch engage. If power for the clutch comes from the relay, check the control side - ie- what makes the relay activate, and check the power side of the relay-ie voltage to the clutch.
Check the ground circuit for the clutch, you can also look for a high resistance in the circuit from the relay to the clutch and on the ground side with and ohm meter. You should be able to do this without running the engine. When checking for ohms make sure power is off or you may get bad readings
If the control side of the relay is not making the relay work, then it could be the low pressure switch, or wiring, could be the on/off switch in dash or wiring
The low pressure switch turns the AC system off if there is a low charge - typically below 20 psi.
Find a wiring diagram and trace the system out.
99 Limited 4wd e-locker Desert Dune Metallic
06-20-2022, 08:54 AM
#18
I’ll be digging into my FSMs this weekend.
99 T4R SR5. OME 906s rear.Stock front springs with 1/4" spacers and Bilstein HDs all around. B&M trans cooler. Deck plate mod and rear diff breather mod. Blacked out bumpers and graphite wheels. Cobra CB in the ashtray. Tundra 199 brake upgrade. Pioneer MVH360BT head unit.
Necessity is the mother of invention.
Recent studies have shown that aggressive therapy combined with owning Toyotas, can be affective in breaking the cycle of Jeep addicition.
06-20-2022, 11:17 AM
#20
Do you have 12+ volts at the connection on the compressor at idle? Is it possible the air gap on the clutch is too wide? it should be about .025".
06-20-2022, 11:51 AM
#21
Real Name: Patrick
Real Name: Patrick
After consulting my 2000 EWD, it looks like the ac amplifier is looking for engine rpm from the ecm in order to engage the ac clutch. My guess is your problem has to do with that part of the equation. Either the ecm isn't sending a good engine rpm signal to the ac amplifier or the ac amplifier isn't telling the ecm to increase the idle so the ac compressor can engage.
06-20-2022, 03:53 PM
#22
What's the engine RPM at idle? (not what's on the cluster, get another instrument to check - OBD-II reading, etc.)
The AC amp won't activate the clutch unless RPMs are sufficient. (this is an issue in one of my other toyotas... I have to tap the gas to get it to engage, then idle-up keeps it engaged)
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
06-20-2022, 05:20 PM
#23
Real Name: Jon
Real Name: Jon
So your thinking is the idle up isn't working. Very good thought.
06-20-2022, 06:47 PM
#24
Sort of - the 5VZ doesn't idle up much with AC. I'm thinking that the AC system thinks the engine is too low in RPM to turn on, not so much whether the idle-up works. (idle up is controlled with the idle air controller these days, not a separate VSV like in the 80's and early 90's Toyotas).
06-21-2022, 01:52 PM
#25
So, when the engine is first started, it will rev to about 1300 and if I push the AC switch it will rev to about 1400.
I hope the amplifier isn’t the issue, I replaced it not long ago, and it is an OEM part
06-21-2022, 03:10 PM
#26
Real Name: Patrick
Real Name: Patrick
What about when the engine is at operating temperature?
06-21-2022, 07:27 PM
#27
When at operating temp, it does not jump up in rpm
06-21-2022, 10:16 PM
#29
Did you try what this member suggested? As if the voltage is there at idle?
I have not had time yet.
