Old 06-21-2022, 10:51 PM #31
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by T4Rscott View Post
When at operating temp, it does not jump up in rpm
That’s why your ac clutch isn’t engaging at idle. The ac amplifier isn’t seeing a high enough engine rpm to allow for compressor clutch engagement. I wonder if there is a way to bypass that.
Old 06-21-2022, 11:08 PM #32
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
For testing, can't he just apply 12volt to the magnetic clutch compressor and monitor the ac clutch feed wire with a mult meter to see if it's kick on and off propetly?
See if it the clutch compressor working properly.
I just tape the wire jumpers in place and monitor all from in cab powering the ac clutch off our cigarette lighter adapter plug.
If the meter is going 12volt then when it clicks goes out when the ac relay kicks on and off. The ac amplifier is working properly.
If it's not sending voltage yo the mag clutch the issue would be in the sc circuitry.
If nothing else these jumpers would eliminate components as good or bad if nothing else?
Old 06-22-2022, 11:39 AM #33
Real Name: Patrick
Real Name: Patrick
Since the compressor clutch engages at higher rpms then that part of the circuit is intact and not the issue. The problem is the ac amplifier not telling the compressor clutch to engage at idle which would be due to low engine rpm. Since it engages at higher engine rpm's I would think that the signal from the ecm is fine. I think the most likely culprit is the ac amplifier not telling the ecm to idle up for the clutch to engage. Either the ac amplifier is at fault (not likely since it was replaced with OEM) or the circuit between the ecm and ac amplifier for that signal/request is the problem.
Old 06-22-2022, 03:17 PM #34
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Man I hope it's not his ac amplifier again.. My ac issues are mostly rotted out Condensers. Warn out compressors.
I was theorizing that the gap in the clutch is just big enough. That at low rpm it engages and slips and at higher rpm it latches and doesn't slip. However, your not getting the correct rpm signal or the ampflier not sending the engage signal at low rpm.
Maybe the densos magnetic clutches are all or nothing as I can't say I even had a magnetic ac clutch fail on a Toyota.
Old 06-22-2022, 03:44 PM #35
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
So let's start from the beginning I guess?
What is the confirmed engine idle after warm up?
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 06-22-2022, 09:08 PM #36
T4Rscott's Avatar
T4Rscott T4Rscott is offline
T4Rscott is on a distinguished road
T4Rscott's Avatar
No voltage at idle, zero, zip, nada….😡
99 T4R SR5. OME 906s rear.Stock front springs with 1/4" spacers and Bilstein HDs all around. B&M trans cooler. Deck plate mod and rear diff breather mod. Blacked out bumpers and graphite wheels. Cobra CB in the ashtray. Tundra 199 brake upgrade. Pioneer MVH360BT head unit.
Necessity is the mother of invention.
Recent studies have shown that aggressive therapy combined with owning Toyotas, can be affective in breaking the cycle of Jeep addicition.
T4Rscott is offline   Reply With QuoteReply With Quote
Old 06-22-2022, 09:11 PM #37
T4Rscott's Avatar
T4Rscott's Avatar
It’s within spec 7-750
Old 06-22-2022, 09:24 PM #38
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
@badluck is on the correct path. It's in ac circuitry. His theory are extremely solid. He explains it on my question post on how to test it with wire jumpers from your cab.
Old 06-23-2022, 08:33 AM #39
T4Rscott's Avatar
T4Rscott's Avatar
I just have to know where to look, and what to test.
Old 06-23-2022, 12:09 PM #40
Real Name: Patrick
Real Name: Patrick
I have a 2000 EWD which would be close, but you really need to find a 99 EWD to reference for circuit testing.
Old 06-23-2022, 03:20 PM #41
I'll see what I can dig up tonight when I get home, if I forget to post anything by like Saturday just ping me in the thread; this week has been a bit chaotic so I've been known to get distracted.
Old 06-24-2022, 03:33 PM #42
T4Rscott's Avatar
T4Rscott's Avatar
Is 5 volts normal measuring from the back side of the connector on the amplifier while it’s connected?
My manual says positive battery voltage. Doesn’t specify an amount
Old 06-24-2022, 03:57 PM #43
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Battery voltage is what the voltage is at the terminal is. So 12.4 to 12.8 would be a example of battery voltage.
Old 06-24-2022, 04:26 PM #44
T4Rscott's Avatar
T4Rscott's Avatar
Well then, that’s not good.
I’m trying to get another amplifier to try.
Old 06-24-2022, 04:28 PM #45
T4Rscott's Avatar
T4Rscott's Avatar
I went through the diag for the ac. Pin 3 to ground with clutch engaged was 5v
compressor , issue , i’m , pressure , system
I'm baffled - Thunk, clunk, pop! WTH WRfarmer 3rd gen T4Rs 6 07-30-2019 03:25 PM
Help! Lean has me baffled... kdub351 5th gen T4Rs 29 04-02-2019 02:19 PM
Feeling Baffled. WeldTightFab 4th Gen T4Rs 1 07-27-2015 11:05 AM
My Mechanic is Baffled scrbear11 4th Gen T4Rs 17 07-28-2013 11:12 PM
I'm baffled... 1995 4runner dwighter Classic T4Rs 1 02-07-2011 01:50 AM
