Originally Posted by T4Rscott
When I step on the gas pedal the clutch engages, and when I let off, it will stop.
I understand what you are saying about the gauges. However, the pressure was fine at the time it was serviced and was still doing the same thing. I will look into a set from Harbor Freight.
I would just verify with gauges.. As my limited AC wouldnt work at all. Thought all i just have a bad pressure switch because the PO had the ac disconnected and I figure the Switched just failed. So when I took it to my buddys to have it evacuated to replace the switch... I only had 10 pounds psi. My 1997 limited has a leak. Hopefully the dye in the system will so me where this leak is.. I changed the switch anyhow. Put a almost 2 cans of 12 oz refrigerate in and See if i can find my leak.
Yours could be perfect pressures. It will rule it out.
I think if your system is all checkes out and your amplifirer is good.. You have a wiring power issue somewhere ad that is all that is really left. :-(
I did finally get the electrical diagrams in photo form on this thread for the 1999 model year..
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
