Old 06-29-2022, 04:02 PM #16
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I have a parts rear hatch that I slice wires off to patch the broken wires in the loom. If you want a section let me know.. We work out a deal for a section of wire. ( most people don't care and just patch.. I take several inches out and solder seal both side past the bad spots so it never happens again for at least 20 Plus years.. :-)
Old 06-29-2022, 04:32 PM #17
McLoven1t562 McLoven1t562 is offline
McLoven1t562 is on a distinguished road
Originally Posted by Bad Luck View Post
The switch and wiring would be what I check next.
yea I'll get my tester out and start probing around on one of my days off, see if I can find the culprit. I love our back windows so it'd be great to have the switch working again lol
I roll that sucker down on the freeway but occasionally you get those weird glares off vehicles and have to roll it up a foot to utilize the window tint =P
McLoven1t562 is offline   Reply With QuoteReply With Quote
Old 06-29-2022, 05:15 PM #18
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by McLoven1t562 View Post
Nope, key doesn't let it go down. Yea that's my concern is more the wiring, I don't mind replacing like a module, just terrified that it may be an issue somewhere in the miles of wiring lol - my sunroof has that cement grease issue too, but out of the two, I miss my rear window a million times more then my sunroof =P
Its most likely the wiring as 90% of the hatch and driver side door circuit issues are the wiring broken and shorting . It can fool you as the wire can be broken and the insulation still intact. If the key works. It's not the control module. Feel the wires as well.
Old 06-29-2022, 05:25 PM #19
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
How many switches go bad I wonder? As I haven't seen one of the back windows switches bad yet but definitely possible.
Old 06-29-2022, 05:37 PM #20
Yea I would definitely put my money on a wire or wires rather then the switch....we even swapped like 3 switches at my buddies property because he has several 3rd gens he parts and sells whole...none of them made a difference lol
Old 06-29-2022, 05:51 PM #21
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
That means you ruled out the switch
Old 06-29-2022, 07:27 PM #22
ValentiOl ValentiOl is offline
Real Name: AnnanuriBI
ValentiOl is on a distinguished road
Hi everyone. I was just thinking about upgrades and this came to mind.
On the Lariat versions of the F150 and the King Ranch theres an option to get a power rear sliding window.
I have the XLT with the same 3 split window in the back but i didnt get a power window option.
I think i herd that make aftermarket kits to buy and install?
Does anyone have one of these or know were i can get one?
I think it would help a lot when backing my boat up to be able to communicate out that window instead of having to hang out the drivers door
ValentiOl is offline   Reply With QuoteReply With Quote
Old 06-29-2022, 07:45 PM #23
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
More than once i thought my rear window was malfunctioning… turns out, if you have the window lock button engaged, it wont roll down with the switch.
Also, my key doesn’t work the back window for some reason. Have yet to dig into that
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 06-29-2022, 07:54 PM #24
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The rear hatch cylinder lock is notorious for freezing up. Try to graphite lubercatimg the locks in your 4 runner...
Old 06-29-2022, 09:59 PM #25
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Every 4Runner has the rear hatch window that rolls down so what are you talking about?
Old 06-29-2022, 11:06 PM #26
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I was thinking the same thing?
Old 07-01-2022, 10:17 AM #27
lol for some reason he's asking us for advice about his F-150 in a 3rd Gen 4Runner area of the 4Runner forum
I don't touch Ford trucks so I have absolutely nothing to add in terms of advice
Old 07-01-2022, 05:32 PM #28
lol so check this out.....I had the switch actually disconnected and sitting in my glovebox so no one would mess with it. Well after you mentioned the key, I've opened/closed it a few times like that.
Sitting at a red light during todays lunch break, I just grabbed the switch and threw it on for the hell of it......THE WINDOW OPENS & CLOSES WITH THE SWITCH AGAIN!!!!!!!
problems , rear , sliding , troubleshoot , window
Another reason I love my 4R’s sliding rear window!!! nghiS4 4th Gen T4Rs 13 03-21-2018 11:20 AM
Advice - rear sliding window incident Spokanesteve 5th gen T4Rs 5 10-28-2016 10:36 PM
Squeaky rear sliding window... trdsport253 5th gen T4Rs 5 06-29-2015 01:40 PM
Rear sliding window switch AppSt92 3rd gen T4Rs 2 12-11-2012 07:54 PM
Other vehicles w/power sliding rear window? Riser General Discussions 12 10-24-2011 09:12 AM
