07-27-2022, 12:37 PM
#16
Originally Posted by 19963.4lsr5
And check the cable tightness at the starter while you’re down there.
Copy that, the starter rebuild process took care of that.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
07-27-2022, 12:38 PM
#17
Originally Posted by Bad Luck
I’d do a voltage drop on the positive cable to the starter while cranking too
Excellent idea, thank you!
07-27-2022, 01:23 PM
#18
It’s been my experience that rebuilds only replace what is broken.
They may never have greased the bendix or replaced the bearings/bushings. Just slapped a cheep contact kit and put it back on the shelf.
07-27-2022, 04:50 PM
#19
Yeah, that's a good possibility since the PO replaced it with a Carquest unit.
07-27-2022, 04:51 PM
#20
Originally Posted by SaulG
Take it by any O'apazone and have battery checked with a load tester, not a DVM. Second opinion an all . . .
Yeah, not a bad idea. Orielleys' auto did it with their load tester gizmo and more than like AutoZone will have the same thing but it's always good to have second opinion.
I have a carbon pile load tester at home and the battery checked out fine.
07-27-2022, 04:54 PM
#21
The 97 project I bought needing an engine and trans came with a CarQuest Alt. Three years later the brushes were worn. So I put an OEM brush set in it. Have yet to test it. It’s my spare. My 88 Daytona needed an AC clutch so I bought a reman compressor. Yea, the compressor had a pretty paint job and the dirty clutch coil and a nick in one of its wires rendering it useless. They never even tested anything.
07-27-2022, 08:24 PM
#22
Thank you all for the ideas.
Part of me thinks it's the one year old Interstate battery because I was watching the interstate guy put his DVM on the bat terms and she went down as low as 10.7vdc during engine cranking, which the guy says "it's normal". So, he didn't want to warranty it out.
Yes, that's good. Lowest acceptable cranking voltage is 9.6v I believe. Monitoring cranking voltage is really a load test on the battery. Agree with others that said to do a voltage drop test on the cable running to the starter and make sure the connection is secure.
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
07-30-2022, 09:06 AM
#23
Well folks,
My daughter came over last night so we ran some quick checks before the monsoons hit and we ran for indoors.
Here's a video of the starter pulling 400 amps My normal DC clamp is only good for 100amp max, so I had to pull out the big gun which is 400 or 1000 amps. In the video I mistakenly said 400/100 amps.
Anyway, as you can see, the starter still cranks slowly even with a second vehicle giving it lots of juice. Charging voltage is around 13.5ish but that starter is drawing down a one year old battery quite a bit.
The clock is ticking for us to depart on Monday for Ouray, CO for a week of wheeling and camping so this might have to be what it is until we return. I have lots of prep work to do for this trip as this is the first time my 16yo daughter is taking her own 4runner with her friends and following me up there. Prepping two rigs is quite a bit of pressure so I'm prioritizing my To Do list accordingly.
If the videos give you more or different insights, please pipe up. As always, constructive feedback is always appreciated.
Video link Shared album - A. Ali - Google Photos
Cheers.
Ali
07-30-2022, 10:19 AM
#24
She's cranking slowly!
The only specs I found on the starter are no load amps.
100a for the 1.8kw starter
90a for the 1.4kw starter
I can put my clamp on on my 97 and see what it pulls but not anytime soon
07-30-2022, 01:34 PM
#25
Real Name: Patrick
Real Name: Patrick
That high of an amperage draw leads me to believe you have high resistance in the positive cable to the starter. Were you able to do a voltage drop on the positive cable while cranking?
07-30-2022, 04:50 PM
#26
I feel you're right and haven't had a chance to crawl under there at the moment. She's gutted the interior and I'm running wires all over the interior!!! That voltage drop check is on my to do list.
07-30-2022, 08:08 PM
#27
Like
@ spartacus
said, fuel pump is most likely the issue. Has the filter been changed lately?
07-30-2022, 09:31 PM
#28
Real Name: Jon
Real Name: Jon
Is the start positive cable going from the starter to the battery getting warm?
Also verify your engine block ground is good and clean just like the positive wire. As it right below the oil filter it can easily get messed up.
If it is not the Battery, nor the cables, then the only thing left is a bad starter issue..
Unless there is a pile of resistance the engine itself causing the slow spin which is extremely unlikely.
07-30-2022, 10:01 PM
#29
Recently on a couple starters in my fleet, I've had to pull the brush cap off and clean up the commutator.
This is my Honda 4 wheeler - acted like the battery was dead.
Subaru did the same. Both cranked no problem after 5 seconds with the emory in the lathe.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
07-30-2022, 10:38 PM
#30
Real Name: Patrick
Real Name: Patrick
Originally Posted by LittleCaesar
Like
@ spartacus
What does the fuel pump have to do with the slow cranking speed?
