Old 08-04-2022, 06:57 PM #1
T4Rscott's Avatar
T4Rscott T4Rscott is offline
T4Rscott is on a distinguished road
T4Rscott's Avatar
ECM swap
So as some of you know I’ve been dealing with an annoying AC issue.
After a lot of diagnostics I believe my ECM may been the culprit.
I obtained a used ECM from another 99 4Runner and it has a chipped key with it. Is there anything I need to do to get it to work in my SR5?
Thanks
99 T4R SR5. OME 906s rear.Stock front springs with 1/4" spacers and Bilstein HDs all around. B&M trans cooler. Deck plate mod and rear diff breather mod. Blacked out bumpers and graphite wheels. Cobra CB in the ashtray. Tundra 199 brake upgrade. Pioneer MVH360BT head unit.
Necessity is the mother of invention.
Recent studies have shown that aggressive therapy combined with owning Toyotas, can be affective in breaking the cycle of Jeep addicition.
T4Rscott is offline   Reply With QuoteReply With Quote
Old 08-04-2022, 07:08 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Thanks
If it has an immobilizer (chipped keys) then your SR5 doesn’t have the components and wiring/connectors necessary to read the chipped key to allow the ecm to start the engine.
It would be a lot of work to add the necessary components in order to make your new ecm work with your current vehicle. I’d recommend finding another ecm that doesn’t have an immobilizer. If it helps with your search, for your year only Limited trims have an immobilizer in the ecm.
Old 08-04-2022, 08:29 PM #3
T4Rscott's Avatar
T4Rscott's Avatar
Just my luck!!😫
Old 08-04-2022, 08:32 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
See if you can match the part number of your ecm in your rig now.. Like Badluck says your rig cant use that ecm for the wiring not being there.:-(
Old 08-04-2022, 08:33 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Old 08-05-2022, 01:08 PM #6
Just my luck!!😫
Unless you are handy with electronics and want to desolder / solder an 8-pin SOIC EEPROM on the board...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-05-2022, 03:46 PM #7
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I've learned that the ECMs have to be a perfect part number match in order to guarantee 100% compatibility, it's printed on the top of the case. Even if you pick the same year and drivetrain, like 99 4WD, there are still some minute differences based on trim models and other options. Sorry you had to learn that the hard way, I would try and return it back to the yard/company you got it from for a credit.
326WHP 347TQ
Old 08-05-2022, 08:45 PM #8
T4Rscott's Avatar
T4Rscott's Avatar
So, luckily the guy I bought it from may have one out of 99 SR5.
Also, I was curious; has anyone ever heard about jumping pins 4 and 13 on the OBD2 connector? I hear it will reset and relearn the key in many Toyotas.
4runner , chipped , ecm , key , work
Bad_Vision's 1985 Toyota 4RUNNER TDI Swap (Completed swap) Bad_Vision Classic T4Rs 211 10-06-2019 10:56 PM
my 92 budget build. engine swap and front end swap? bhenry92 Classic T4Rs 4 08-06-2013 05:42 PM
Im starting to get the 2.5yr blues...solid front axle swap or lt1 ls1 v8 swap? 240m3srt 3rd gen T4Rs 29 10-03-2011 12:15 AM
94 4runners-engine swap, or front end swap? pats for sale as well jimmy94 Classic T4Rs 7 05-16-2011 09:48 PM
92 fourrunner swap 3.0 L standard Engine Swap compatibility cshlakoff Classic T4Rs 0 02-17-2008 12:42 PM
