09-28-2022, 01:56 PM
#16
Real Name: Keith
Real Name: Keith
I have 2-2.5" rear lift, and the stock rear brake hose does not appear to be in danger of being stretched ...based on seeing it up on a lift, at full droop, in the service shop.
09-29-2022, 09:23 AM
#17
Your shocks are likely still stock length of very close. I am running OME 906's and Nitrocharger shocks. I did not need any brake line extension either, its juuust close to tight, but still has slack at full stuff or droop.
The 4Runner Show
09-29-2022, 09:27 AM
#18
Real Name: Patrick
Real Name: Patrick
Originally Posted by texadelphia
I noticed the other day that the rubber on my front brake lines is cracked. Anyone know of a good quality brake line replacement for the front brakes? They're like $100 from the dealer and $8 from RockAuto so it seems like there must be a middle of the road option.
I’m a little late to the party, but I ordered braided steel brake hoses for the front for a 1st gen Tacoma. It eliminates the hard line at the caliper, but does require a banjo bolt and copper crush washers for the new brake line to bolt to the caliper.
09-29-2022, 06:51 PM
#19
Real Name: C8H18 Mike
... braided steel brake hoses for the front for a 1st gen Tacoma. It eliminates the hard line at the caliper, but does require a banjo bolt and copper crush washers for the new brake line to bolt to the caliper.
If you buy the 1st gen taco lines from Stoptech, Toytec or Wheelers they come with the banjo bolts and very thin copper washers.
I found O'Reilly's has a banjo bolt and washer kit for $4 that has thicker washers - many threads about banjo bolt being too long and not sealing.
I also found 1.5mm thick M10 copper washers on Amazon for a good price ($9 for 30)
I got my.lines from Wheelers
Just FYI if going this route for all
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
09-30-2022, 09:41 AM
#20
What's the benefit of this setup? Are the hard lines a common failure point?
1997 SR5, 3.4L, Manual
09-30-2022, 11:24 AM
#22
Real Name: Patrick
Real Name: Patrick
I don't like the weird hard line from the caliper. It makes it awkward when removing the caliper. There was no price difference between replacing just the current brake hose and replacing the hard line at the caliper with the brake hose. Seemed like an obvious decision for me.
09-30-2022, 11:50 AM
#23
Makes sense. That hard line does make things awkward when doing brakes.
Does that banjo bolt work with the stock calipers or do you need TBU calipers?
09-30-2022, 11:52 AM
#24
Originally Posted by brillo_76
No they don't unless they rust through. Makes it easier to change brake pads and looks cool...
Never underestimate the importance of looking cool.
09-30-2022, 01:22 PM
#25
Real Name: Jon
Real Name: Jon
Nothing wrong with that. Pull the clup on the flex line to easily change the pads. Or you can just pull the bolt that the flex line holds to make it even easier. I mostly just remove the bolt as I think that's the fastest way to change the pads. However this just how I do it.
09-30-2022, 01:47 PM
#26
Real Name: Patrick
Real Name: Patrick
The banjo bolt works with my stock calipers (S13WM). I don't see why they wouldn't work with the S12WE calipers as they use the same short hard line at the caliper.
I've done both methods before, but I prefer the extra movement from the longer section of flexible hose. To each their own though and it's all personal preference. I don't remove the calipers often, but it makes a difference for me.
09-30-2022, 03:23 PM
#27
Now the rubber flex lines can fail by cracking and the inner rubber collapse in shutting off
I removed those hardlines after installing spindle gussets and went for taco lines.
I know of 2 guys with gusseted spindles that experienced hardline failures, 1 lost brakes. JM2C
Sent from my Pixel 4 XL using Tapatalk
