11-14-2022, 01:53 AM
Anyone know what set of Fender Flares fit?
Specifically bolt ons but really anything works i was looking at Ebaymotors and remembered that the Tacoma and 4Runner share something idk if it’s the flares but i don’t want to just “make it fit” had to be the right one you know.
11-14-2022, 04:02 PM
Real Name: Patrick
Real Name: Patrick
https://www.google.com/search?q=site...t=gws-wiz-serp
11-14-2022, 05:01 PM
Originally Posted by Bad Luck
How does giving me a link to the Forums help? I already looked and i can’t find anything?
11-14-2022, 05:08 PM
Real Name: Patrick
Real Name: Patrick
If you've looked through all the links that Google pulls up and can't figure out what flares fit then that's unfortunate. Maybe another member here will have time to spoon feed you the information you are after. Good luck
11-14-2022, 05:39 PM
There are two types came with factory, (1) Large flares as seen in limited and post 2000 SR5: These flares require some drilling into the body. You can also try this: Remove all plastic clips and mount just by the bolts to the mudguard inner splash guard bolts, and for the top curvature, use clear RTV silicone to glue to the body panels. This will hold the flare.
2) Easiet is to locate pre 2000 SR5 flares. Just bolts to splash guard bolts but this is the skinny kind. I have extended these by adding the universal rubbery fender extensions available online.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
11-14-2022, 06:10 PM
Real Name: Jon
Real Name: Jon
All I know for certain are the factory oem 2 styles that the other user has mentioned. There were 3 types in the 3rd gens. The 3rd us just a chrome strip that I don't really flares .
11-14-2022, 06:58 PM
Bushwhacker makes some also.
BxBuilt supposedly was going to make some also. Who knows on that one…..
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
11-14-2022, 07:04 PM
Originally Posted by brillo_76
Bushwacker make some that fit really well and use the oem holes for mounting? Or do you have to make new holes to mount?
i’m gonna have to make new holes to mount i haven’t touched my fenders yet but i want to make them wider
11-14-2022, 07:05 PM
funny cause i was just looking at bushwackers right now and that look is what i’m aiming for exactly
11-15-2022, 10:18 AM
Here's what a set of BW Extend-A-Flares look like on my 2000 SR5. These have been on the truck for 13 years or so. Hope this helps.
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
11-15-2022, 11:02 AM
That I don’t know. I don’t have any experience with them.
11-15-2022, 12:05 PM
Real Name: Devan
Real Name: Devan
I believe they did make them already but stopped, I remember SRQ selling them back in early 2020. They're a shit company though so not too surprised, if they can't deliver on headlights I can't see them delivering on fenders
11-15-2022, 02:35 PM
You have to drill holes in the rear doors to mount that part of the flare. All of the rest of the mounting points are the stock locations.
