Old 11-22-2022, 06:00 PM #1
Kenrunner's Avatar
Kenrunner Kenrunner is offline
Kenrunner is on a distinguished road
Kenrunner's Avatar
Do I Need A Special Rear Wiper?
‘98 SR5, rear wiper needs replacing. Difficult finding any CLEAR advice/instruction about whether I need a very particular wiper, as it has that bracket with 2 small screws that attaches it to the wiper arm, or if I can just get away with buying something “off the rack” and make it work.
Can anybody tell me definitively either way?
Thanks!
Kenrunner is offline   Reply With QuoteReply With Quote
Old 11-22-2022, 06:04 PM #2
GhostRing's Avatar
GhostRing GhostRing is online now
GhostRing has a spectacular aura about GhostRing has a spectacular aura about
GhostRing's Avatar
I seem to remember having similar difficulty with mine, and ended up buying an appropriate width wiper
and sliding the old rubber out and sliding the new rubber blade in. Holds up just fine.
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is online now   Reply With QuoteReply With Quote
Old 11-22-2022, 07:10 PM #3
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
Thanks!
You either need to get an OEM rear wiper, just replace the rubber blade itself, or you can use an adapter. That's the option I went with, and you can see what I used here.
Skulking is offline   Reply With QuoteReply With Quote
Old 11-22-2022, 08:48 PM #4
Kenrunner's Avatar
Kenrunner's Avatar
Yeah that’s the route on which I appear to be going down.
Thank you for replying so fast.
Old 11-22-2022, 08:49 PM #5
Kenrunner's Avatar
Kenrunner's Avatar
Thanks so much for the info. I really appreciate the link!
Old 11-23-2022, 01:52 AM #6
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
Thanks!
my recommendation is to go for the adapter and a 13 inch blade...makes replacing the blade down the line a lot easier as you can just use any old J hook.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 11-23-2022, 03:11 AM #7
Kevin11 Kevin11 is offline
Kevin11 is on a distinguished road
I saw a video about replacing the OEM rear wiper on YouTube before, you can have a check
Kevin11 is offline   Reply With QuoteReply With Quote
Old 11-23-2022, 12:16 PM #8
jgue467's Avatar
jgue467 jgue467 is online now
jgue467's Avatar
‘98 SR5, rear wiper needs replacing. ...
Thanks!
Using some of the links below lead to this on amazon, an OEM blade:
Sorry! Something went wrong!
jgue467 is online now   Reply With QuoteReply With Quote
Old 11-23-2022, 12:18 PM #9
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
The link you posted doesn't work.
Old 11-23-2022, 12:50 PM #10
jgue467's Avatar
jgue467's Avatar
Tried again, same result, not sure why amazon links aren't copying/pasting correct for me today, so instead just search for: 'Genuine Toyota Parts - Blade, Rr Wiper (85242-35010)'.
Old 11-23-2022, 02:23 PM #11
bdjcl bdjcl is offline
bdjcl is on a distinguished road
that's what I bought. There are two small philips head screws that you remove, take off the old wiper and put the new one on.
'98 Corolla LE 193k miles
'98 4Runner Limited 215k miles
bdjcl is offline   Reply With QuoteReply With Quote
Old 11-23-2022, 07:33 PM #12
This is what I use as a replacement.
Old 11-28-2022, 01:09 AM #13
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
That's what I did, too. Otherwise, dealer. I did not see any way to MacGuyver a full refill exchange.
My Backyard Frame Swap
Old 11-28-2022, 06:54 PM #14
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
I know I’m going to get booed out of here for this one, but the dealers stock this wiper, no adapters needed.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 11-28-2022, 08:28 PM #15
nah, no boos here, for me at least the convenience of being able to use just any old J hook wiper was the appeal, it'd save me some time getting one shipped or just going to pick one up if I could go to Walmart and get one there.
I understand why some prefer the dealer wiper, but for me the convenience is more worthwhile
281k Miles
Build Thread
buying , rack” , rear , wiper , “off
4th gen rear wiper adapter for using non OEM wiper blades alia176 4th Gen T4Rs 8 08-18-2022 12:36 PM
Speakers, Rear Wiper, Wiper Control sam.basye For Sale: T4R Items 2 12-08-2016 02:21 PM
Rear window, rear defrost, rear wiper not working BREX25 3rd gen T4Rs 14 06-23-2013 11:22 PM
4LO light comes on randomly in 2H, rear wiper weird, rear window sticks! Summit Problems & Warranty Issues 5 11-29-2012 07:48 PM
