11-22-2022, 06:00 PM
Do I Need A Special Rear Wiper?
‘98 SR5, rear wiper needs replacing. Difficult finding any CLEAR advice/instruction about whether I need a very particular wiper, as it has that bracket with 2 small screws that attaches it to the wiper arm, or if I can just get away with buying something “off the rack” and make it work.
Can anybody tell me definitively either way?
Thanks!
11-22-2022, 06:04 PM
I seem to remember having similar difficulty with mine, and ended up buying an appropriate width wiper
and sliding the old rubber out and sliding the new rubber blade in. Holds up just fine.
Build Etc...
If it ain't broke, fix it 'til it is.
11-22-2022, 07:10 PM
Thanks!
You either need to get an OEM rear wiper, just replace the rubber blade itself, or you can use an adapter. That's the option I went with, and you can see what I used here.
11-22-2022, 08:48 PM
Yeah that’s the route on which I appear to be going down.
Thank you for replying so fast.
11-22-2022, 08:49 PM
Thanks so much for the info. I really appreciate the link!
11-23-2022, 01:52 AM
Thanks!
my recommendation is to go for the adapter and a 13 inch blade...makes replacing the blade down the line a lot easier as you can just use any old J hook.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
11-23-2022, 03:11 AM
I saw a video about replacing the OEM rear wiper on YouTube before, you can have a check
11-23-2022, 12:16 PM
‘98 SR5, rear wiper needs replacing. ...
Thanks!
Using some of the links below lead to this on amazon, an OEM blade:
Sorry! Something went wrong!
11-23-2022, 12:18 PM
Real Name: Patrick
Real Name: Patrick
Originally Posted by jgue467
The link you posted doesn't work.
11-23-2022, 12:50 PM
Tried again, same result, not sure why amazon links aren't copying/pasting correct for me today, so instead just search for: 'Genuine Toyota Parts - Blade, Rr Wiper (85242-35010)'.
11-23-2022, 02:23 PM
that's what I bought. There are two small philips head screws that you remove, take off the old wiper and put the new one on.
'98 Corolla LE 193k miles
'98 4Runner Limited 215k miles
11-23-2022, 07:33 PM
This is what I use as a replacement.
11-28-2022, 01:09 AM
That's what I did, too. Otherwise, dealer. I did not see any way to MacGuyver a full refill exchange.
My Backyard Frame Swap
11-28-2022, 06:54 PM
I know I’m going to get booed out of here for this one, but the dealers stock this wiper, no adapters needed.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
11-28-2022, 08:28 PM
nah, no boos here, for me at least the convenience of being able to use just any old J hook wiper was the appeal, it'd save me some time getting one shipped or just going to pick one up if I could go to Walmart and get one there.
I understand why some prefer the dealer wiper, but for me the convenience is more worthwhile
281k Miles
Build Thread
