01-16-2023, 12:22 PM
Throttle Body Source?
I have a 2000 4Runner Limited with 280K miles, and I'm looking for a new throttle body (I believe it is part number 22210-62220).
Currently, my idle sometimes acts a little strange, and I wanted to clean the IAC on my existing throttle body, but screws are completely stripped and I have been unable to remove them, and the throttle body is showing some age.
Due to the age and miles of the truck, I thought I might just replace the whole throttle body with a new one, but it seems to be discontinued or no longer available.
Does anyone know of a source at a reasonable price?
I could roll the dice with a used one on line, and try to clean it up, but I would prefer new one if available...
Any advice would be appreciated.
Lee
01-16-2023, 02:52 PM
Real Name: Patrick
Real Name: Patrick
Lee
If you REALLY want a new one: Buy Genuine Toyota 2221062220 (22210-62220) Body Assy, Throttle. Prices, fast shipping, photos, weight - Amayama
01-16-2023, 03:38 PM
@ Bad Luck
, yes I saw the one on Amayama for $880 (plus shipping). But I can't believe there aren't any out there reasonably priced. They used to be about $350. I can get one for my 2000 Land Cruiser for about $400 (still available).
Is this a supply chain issue, or are they simply all gone and no longer available? If I knew that new ones are no longer available (or at least at a reasonable price), I would try a used one... That's probably what I'll end up doing...
Thanks
01-16-2023, 04:09 PM
Real Name: Patrick
Real Name: Patrick
@ Bad Luck
Thanks
I'm assuming the are no longer made and US inventory is gone. Amayama is the only place showing new in their Japan warehouse, and that may change once you place an order for one from them. I'd try to replace the IAC screws and gasket like brillo_76 mentioned above.
01-16-2023, 11:08 PM
Can you post a photo of the stripped IAC screws? To many members of this forum, indeed many experienced mechanics, completely stripped is a subjective term.
01-16-2023, 11:17 PM
99 4wd limited w/ E/locker
3" RC lift-loaded struts. Sonoran Drop diff and adjustable rear Panhard.
JBA Offroad UCA's, Pro comp Raven 16x8 wheels wrapped in 265/75/16 Gladiator Mt ,APOC INDUSTRIES Rear Trailing arms.
RETIRED USCG Aviation Mechanic/Hc130h Flight Engineer/HH65-A Flight Mech.
SEMPER PARATUS
01-17-2023, 12:22 AM
I stripped my IAC screws and believe I was able to get a dremel cut off on it and cut a slot for a flat head. Came out easy after that.
01-17-2023, 04:59 PM
Real Name: Jerod
Real Name: Jerod
Toyota stopped manufacturing replacement throttle bodies so the inventory got very expensive very fast. A set of vice grips or above mentioned chisel and hammer will get those suckers out. Also have done the dremel trick on those darn grab handle screws, they were so stuck and nothing was getting them out.
I think what we are trying to say is that if you want to avoid paying $350+, buy a $10 tool and get those screws off.
01-17-2023, 05:16 PM
Thanks for the suggestions; it looks like there are no reasonable options for a new one.
I suspect I can drill, dremel, or chisel those screws out, but I was hoping to avoid the risk of damaging the throttle body... Looks like I'll put it on the project list.
Thanks
01-17-2023, 05:20 PM
I did my LC 2000 throttle body and it was about $475 with a discount! Also LC's have a lot of maintenance items than a 4R! so prices are competitive. Love the 4R...
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
01-17-2023, 08:55 PM
The good news is Toyota still makes the IAC screws!
01-18-2023, 10:31 AM
@ nissanh
, I put a new throttle body in our LX470 for about $380. Current pricing for a throttle body (22210-62220) for my 4Runner (seems like Amayama is about the place with availability) is about US$ 924 (886 + 38 shipping)... I do love the 4Runner, but throttle body pricing/availability is not that competitive (at least for a new throttle body)...
Lee
2000 4Runner
2000 Land Cruiser
2004 LX 470
