01-17-2023, 12:53 AM
Am I crazy to sell?
So my 3rd gens been sitting for 2 years. Fuel pump failed. Swapped the pump with a Walbro 190lph and and didn't start for some reason and didn't have time to diagnose. Someone offered me $2500 and I said $3k firm. He is coming to look now.
1996 Limited, no locker with 288k miles. Needs no start issue fixed, timing belt, water pump and maybe a brake master cylinder to be good to go. AOR bumper, hood and left fender needs painted. Ripped leather seats. Other than that pretty clean.
SUSPENSION
Front:
SPC Light Racing Upper Control Arms
OEM LCA w/ES Polyurethane Bushings
SPC LCA cam bolts w/plastic sleeves
OME 881 Coils w/SS 1" Custom Lift sleeves (3" front lift)
Driver side Toytec 1/4" trim spacer
OME 90004 Comfort Sport Shocks
SS Tapered 1.5" Front Diff Drop
Wabfab front sway bar quick disconnects
Rear:
New LC 7.5 wrap coils
Driver side OME rear 10mm trim spacer
OEM cone bump stops installed
Tokico LC Shocks
SS rear sway bar brackets
4" Extended SS brake line
SS Competition Lowered Bump Stops
SS Adjustable Panhard Bar
2nd gen Moog sway bar links
TIRES/RIMS/BRAKES
285/75r16 Treadwright Wardens
1.5" Front Spidertrax Spacers
OEM Satin Black 6 lug rims
231mm 2006 Tundra brakes, OEM pads/shim kit, OEM rotors, Napa reman 13wl Calipers
MISC.
Custom 3" Short Ram Intake w/cone filter
1.5" 4crawler body lift w/steering spacer, front bumper spacer, custom radiator bracket
New Toyota Steering Rack and Pinion
New Koyo A1998 Radiator
Polyurethane rack and pinion bushings
JVC double din mp3 cd deck w/kenwood speakers throughout
Pinch weld mod w/ trimmed flares
Addicted Offroad Front Hybrid Plate/Tube bumper w/LED turn signals
2x ebay 4" Cree LED spot lights
9500lb Tiger Superwinch w/steel line
Am I crazy to let it go for $3k?
01-17-2023, 01:31 AM
high mileage and it doesn't run.. but that bumper is worth 1k at least!... get it running and you could fetch 2x that number.
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
01-17-2023, 01:41 AM
Real Name: Blair
Real Name: Blair
Yes. The nice men be over soon with a special jacket that will prevent you from signing any documents shortly.......
01-17-2023, 02:15 AM
I'm curious to know your reasons why, other than the fact that it needs work done. Not trying to get personal, just curious. But some things to consider:
- current market/inflation
- do you need the money for something else
- why not keep it and continue working on it
- if it gets fixed, you could use it as your daily/grocery getter
- I wouldn't sell it
- please don't sell it
- keep it forever
Sent from my SM-S908U using Tapatalk
01-17-2023, 02:33 AM
- keep it forever
The money will go towards my 2013 CTS-V to bring it to around 700whp.
Tired of working on it. Have a 2012 Tacoma that I built for wheeling.
Have a clean 2000 Honda Accord for daily grocery getter but it's my daughter's new car.
I really want to fix it and keep it but no time to touch it.
01-17-2023, 03:53 AM
Real Name: N/A
Real Name: N/A
That's a good deal. The issues you listed are straight forward fixes and that's before you consider the mods. Normally non-working vehicles are sold with no idea of what is wrong, so people will ask for a lower price since they could get screwed on fixes.
Since yours seems to have straight forward fixes, and a good frame it's an easy purchase at that price. A 4wd 4runner in the coastal states with no rust would sell for about that and that's not even considering the mods. They sell replacement leather upholster for 4runners, so someone with the smallest amount of DIY could make it a nice vehicle for say 2400 at most. To make an equivalent vehicle would cost much more than what your asking plus the fixes
Your crazy but you do you. Hopefully they treat it well.
1998 4runner 2.7 manual
01-17-2023, 10:31 AM
I'd try my best to make it run, I mean it's either no spark or no fuel.
I'd buy it for 3k right now but I don't have time to drive to colorado, and yes, you're crazy for not trying to get it running and then sell it for at least $7500. or more. If you don't have time to fix it right this second, let it sit until spring. You'll regret selling it for less than you and I know it's worth.
Fix it then sell it.
99 4wd limited w/ E/locker
3" RC lift-loaded struts. Sonoran Drop diff and adjustable rear Panhard.
JBA Offroad UCA's, Pro comp Raven 16x8 wheels wrapped in 265/75/16 Gladiator Mt ,APOC INDUSTRIES Rear Trailing arms.
RETIRED USCG Aviation Mechanic/Hc130h Flight Engineer/HH65-A Flight Mech.
SEMPER PARATUS
01-17-2023, 12:00 PM
Real Name: Christian
I'd say if it is just going to sit indefinitely might as well move it on. Not like you can't find another 3rd gen if you want to get back into the chassis at some point.
01-17-2023, 01:35 PM
Real Name: Ron
Real Name: Ron
Sell it and go, you've obviously lost interest in it, so unless you want to spend the time trying to get a few more $$$ sell it and go.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
01-17-2023, 02:27 PM
Real Name: Blair
Real Name: Blair
At least pull the bumper with winch and lights. Knock 300 off the price if you have to and save or sell the bumper and winch combo for 1700. The wait time on AOR bumpers has been very long historically and I'm sure someone would pony up.....just a thought.
01-17-2023, 03:25 PM
I think your crazy. Fix it before you sell it. You'd probably collect double at least.
Market is softening...... finally.
I mean, if you just don't care, and it doesn't matter anyways. But if it's a question of time versus money, man, I would at least kick it over to a shop and let them get it running before you sell it.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
01-17-2023, 04:31 PM
Real Name: Jerod
Real Name: Jerod
This is my thoughts as well. It's obvious that time is a big factor and you've moved on to other projects. But at least throw it at a shop and let them fix it, it would be a fraction for what you'd get extra for a running vehicle.
PS shoulda sold it 1.5 years ago when the used car market was insane!
01-18-2023, 01:09 PM
Real Name: Patrick
Real Name: Patrick
Even if you have to pay someone to fix it you will most likely make the repair cost and much more back by selling it as running and driving. In my area if that was running/driving it would be $8000-$9000 easy.
01-19-2023, 11:39 AM
Well I feel the universe is giving me a sign. Can't find the main keys. Just the spare ignition key and fob. Battery is dead and can't unlock it. I left hood unlatched so I could jump it in the future but for some reason it's closed. Went to find title and it's no where to be found. Go to DMV this morning to get the title and realize it's under my wife's name and they would not give me a duplicate. Haha.
