Old 01-25-2023, 11:33 AM #1
studebaker studebaker is offline
studebaker is on a distinguished road
3rd gen 3.4 flexplate change
Unable to find info regarding changing out the flexplate on a 99 3.4.
I have to change this one due to chipped teeth on ring gear.
Any advice?
Thanks!!
studebaker is offline   Reply With QuoteReply With Quote
Old 01-25-2023, 01:04 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You basically have to remove the transmission and transfer case. Changed the flex plate then put it back together.
Tim the toolman made 3 videos on this and you can find instructions in the Factory Service manual
Toyota 4Runner Auto Trans Replacement (Part 1 of 3) - YouTube
Toyota 4Runner Auto Trans Replacement (Part 2 of 3) - YouTube
Toyota 4Runner Auto Trans Replacement (Part 3 of 3) - YouTube
Old 01-25-2023, 02:58 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Any advice?
Thanks!!
Remove transmission, replace flex plate, reinstall transmission. I would consider replacing the rear main seal while you are there.
Old 01-25-2023, 04:05 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes good idea on the main seal..
Old 01-27-2023, 12:57 PM #5
Originally Posted by brillo_76 View Post
Yes good idea on the mail seal..
Thanks for the reply's.
I had anticipated changing the rear seal and have the rear seal kit (seal and cover gasket) along with the flexplate.
This is a rwd version.
Old 01-30-2023, 08:25 AM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Process will be very similar except you don't have a transfer case for the 4WD.
Other then that darn near identical. :-)
3rd , advice , change , flexplate , gear
Timing Belt and Flexplate? 4'running'26 3rd gen T4Rs 18 03-25-2020 04:17 AM
flexplate nightmare! Squirt 3rd gen T4Rs 32 02-25-2020 02:33 PM
Another Flexplate PSA eastsideride 3rd gen T4Rs 11 12-27-2019 11:47 AM
Flexplate Replacement PSA Neil_R 3rd gen T4Rs 7 12-27-2015 09:48 PM
Flexplate replacement - any advice? napstermike 3rd gen T4Rs 9 07-09-2014 02:15 AM
