Finished up the valve cover gaskets, half moons, cam plugs, and paint. I wasn't sure how the red would look, but it turned out awesome. Just enough shows to be an accent in the engine bay. Not sure I'd have done red without the supercharger. Woulda probably gone with a metallic silver with the stock intake.
Valve cover gasket job was a lot easier than I expected. 3 outta 10 on a 10 point scale.
The VHT Wrinkle paint is very durable and went straight on the aluminum with no primer. I did use a heat gun to get the texture more uniform but it seems to have gotten even better after a couple drive cycles in the truck.
Next up I need to detail the engine bay to make sure I don't have any other oil leaks. Kinda hard to tell at the moment with all the gook from the valve cover leaks.
Video in 3rd post.
