Old 05-22-2023, 10:28 PM #211
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
@fourfive I notice that stuff also, hung mine from tree branch in backyard.
Old 05-27-2023, 05:40 PM #212
Speedy's Avatar
Speedy Speedy is offline
Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough
Speedy's Avatar
Originally Posted by Spiker Engineering View Post
I'd seriously be interested in a second set if you can track it down. Seems like half the battle is finding an original label image for them to use.
PM me if you're up to this, I'll definitely split the expense with you.
Well, I completely struck out at all my local places that make me labels. Seems these Toyota ones printed on aluminum are pretty unique. Once place said they could scan and print in vinyl and would look fine at 10 feet but I wanted a bit better than that.
I ended up finding the ones I needed here:
Labels for 2002 Toyota 4Runner | Toyota Parts
My originals were yellow on aluminum the new ones just seem like white vinyl. Better than no label though.
Speedy is offline   Reply With QuoteReply With Quote
Old 05-27-2023, 06:22 PM #213
Speedy's Avatar
Speedy's Avatar
I've started work on the chassis. I think I mentioned that my hitch Z-bar nuts were not welded to the bar, but sort of press fit. I was worried this could break loose in the future so I had my buddy spot weld them for me. Won't have to worry about them now.
Old 05-27-2023, 10:26 PM #214
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Those would not break loose for a very long time. Nothing wrong with a quick weld on them. I have a set of those so I can make new sets.
Which may be needed down the road as parts become less available.
I figured I would make them out of stainless, but the nuts would have to be hitch rated. Stainless nuts may be too brittle.
Anyways, good progress on your restoration.
Old 05-27-2023, 11:12 PM #215
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
are you selling them? my receiver doesn't have those brackets.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 05-28-2023, 09:59 AM #216
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I am keeping my set to create new ones. I haven't given much thought to making replacement sets at this time. As I don't have a tig welder to weld stainless.
Old 05-28-2023, 11:26 AM #217
about the use of stainless steel. wouldn't that cause bi-metallic corrosion of the carbon steel?
Old 05-28-2023, 12:03 PM #218
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I never seen issues with it. Keep in mind in my environment, everything rusts unless coated. I have a pile of stainless bolts in 4 runners, and I am seeing any reaction yet. Granted, it hasn't been 20 years.
I can give you a better answer in 5 to 10 years.
Old 05-28-2023, 05:29 PM #219
Speedy's Avatar
Speedy's Avatar
Anyone have a habit of checking their spare for air pressure? I had honestly forgotten all about it and mine was dead flat. Original tire from 2002, I may need to look at finding a used "newer" tire for that just in case scenario.
Old 05-28-2023, 08:16 PM #220
Real Name: Mark
Real Name: Mark
Got courious had never checked date of mine, 3200 think I got ya beat
Old 05-28-2023, 11:02 PM #221
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I try to verify pressure as all mine are aluminum, not original spares. So every 5 to 10k miles I drop it down and verify it good psi.
Old 05-29-2023, 06:43 AM #222
I include the spare in the tire rotation so the tire pressure is regularly checked
Old 05-29-2023, 10:57 AM #223
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
But can we just talk about how CLEAN that spare wheel is?! Good grief dude! Lol
Old 05-29-2023, 03:03 PM #224
Speedy's Avatar
Speedy's Avatar
LOL it didn't start off that way.
Old 05-29-2023, 04:33 PM #225
Real Name: Mark
Real Name: Mark
It easy to keep things nice living where @Speedy n I do, I'm +- 4 hr SSW.
Mine is untouched showing a bit of rust bubbles around hub opening.
As far as finding a newer used spare, do you really need to?
What ever gives you the fuzzy's, Mine are just there dark corner of garage mostly.
3rd Gens 400k+ plus miles 23 yrs never needed it, 10 ply MT's or ATs
Out of state wheeling see's light of day, it way down my list.
fluid , miles , rear , recondition , replaced
My better late than never build thread gm350reratliff 4th Gen T4Rs 118 09-06-2022 12:19 AM
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
