Old 02-07-2023, 04:19 PM #1
Rushthezeppelin Rushthezeppelin is offline
Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about
Stuck trying to remove Moog sway bar end links
So I'm trying to see how my truck does without the front sway and if it's something I could live with for onroad or if I want to start looking into disconnecting end links so that I still get the best of both worlds. Unfortunately I ran into a problem trying to remove the control arm side of the moog end links that are currently on there and the ball joint just spins. I guess the OEMs had an allen cut into the end of the bolt for this exact reason but the moogs don't and I'm pretty stumped now how I want to get them out. Regardless I want to replace them because the boot on one is torn up and the bushings are completely shot. Any brilliant ideas for trying to get past this? Only idea I have is to grind some flats into the end of the bolt but I don't have a grinder.
'98 SR5 5 Speed
Rushthezeppelin is offline   Reply With QuoteReply With Quote
Old 02-07-2023, 04:41 PM #2
GhostRing's Avatar
GhostRing GhostRing is online now
GhostRing will become famous soon enough GhostRing will become famous soon enough
GhostRing's Avatar
Does the link have any flats like the picture?
Could get a wrench on there to hold it in place.
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is online now   Reply With QuoteReply With Quote
Old 02-07-2023, 04:52 PM #3
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
This should be the correct answer for the Moog end links.
Skulking is offline   Reply With QuoteReply With Quote
Old 02-07-2023, 05:27 PM #4
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
Yeah, it's usually hard to see with dirt/grease/rust, but there's often a flat in there.
If that doesn't do it, angle grinder it. That's usually what I end up doing when the end links need to be replaced. Spritz with PBLaster the day before, then give it a go with the wrenches, but if it's not happening, don't bother fighting it, just use the spinny grindy wrench on it.
JohnMc is offline   Reply With QuoteReply With Quote
Old 02-07-2023, 06:14 PM #5
As long as I can find that flat I should be gravy, nothing has ever been stuck on my truck yet, including a few OEM parts that probably have never been loosened in 25 years/275k. PB Blaster has gotten everything off with ease.
'98 SR5 5 Speed
Old 02-07-2023, 06:45 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Worse case you can cut them off. I done thst before I don't like using torches or plasma cutters due to the rubber boots and cv joint boots. :/
Takes time, but a dremel or one of the oscillating little saw will cut through it..;) OEM doesn't have any grease fittings on them. I have moogs sway bar links on my front and rear.
Old 02-07-2023, 08:47 PM #7
Sure enough, that plate with flats was there and just covered with grease and road grime. Thanks guys.
'98 SR5 5 Speed
Old 02-08-2023, 12:11 PM #8
MCgrease08's Avatar
MCgrease08 MCgrease08 is offline
MCgrease08 is on a distinguished road
MCgrease08's Avatar
Alright. No one likes a braggart.
Signed - A guy in the rust belt who's fought every single nut and bolt he's touched on his rig.
MCgrease08 is offline   Reply With QuoteReply With Quote
Old 02-08-2023, 12:16 PM #9
So true.
Old 02-08-2023, 12:29 PM #10
Thirded. The rust belt takes no prisoners.
Old 02-08-2023, 01:14 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The rust belt destroys the steel. It can actually swell the bolts and nuts and they will not come out. Granted, most larger fasteners will come out. I personally have had bolts that normally aren't rusty snap off. Like belt adjusting bolts..
It really depends on whether the rigs were maintained and taken care of or not.
For those of us that live in it. It's just simply a way of life. I learned to embrace it and work around it as that is all we can do..
Old 02-08-2023, 06:10 PM #12
Mine is a lifelong CO resident. I appreciate all y'all from the rust belt for your contributions to the Just Rolled In YouTube channel.....
'98 SR5 5 Speed
end , links , moog , remove , sway
4th Gen MOOG Front Sway Bar End Links KS_Runner For Sale: T4R Items 3 02-13-2022 11:20 PM
Moog Sway Bar Links black ripper 58 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 05-17-2016 12:27 AM
Front sway bar removal and extended rear sway bar links. morphious 4th Gen T4Rs 25 11-29-2015 01:36 PM
Are Moog sway bar front and rear links any good? Herculean T4R 3rd gen T4Rs 5 03-26-2015 02:28 PM
Advice on how to remove sway bar end links. stevos758 4th Gen T4Rs 6 10-15-2013 05:00 PM
