03-09-2023, 05:04 PM
#1
official vendor
official vendor
Engine bay refresh project
03-09-2023, 05:12 PM
#2
official vendor
official vendor
So far, I did a compression check, and was quite happy with the results - 200, 200, 210, 200, 205, 200 psi.
I removed the upper and lower plenums, and removed the injector rails.
So now I'm staring at this:
My next decision is do I remove the valve covers? I did the VCGs and half moons only a couple of years ago, but like an idiot, I did not check the valve clearance, or paint the valve covers at the time.
I'd really like to paint the valve covers, but it's impossible to do that well without removing them. It seems like at this point, the extra work of removing the valve covers is relatively small. And then I'd be able to check the valve clearance.
So my first question is (probably one of many to come) - should I remove the valve covers and paint them, and do the valve clearance check?
03-09-2023, 05:19 PM
#3
Senior Member
Real Name: Mark
Senior Member
Real Name: Mark
As oxidized as V/C's are will you be happy with paint job. You won't be able to do as good a clean up on V/C's as if they were removed.
03-09-2023, 05:23 PM
#4
Elite Member
Real Name: Jerod
Elite Member
Real Name: Jerod
I'd really like to paint the valve covers, but it's impossible to do that well without removing them. It seems like at this point, the extra work of removing the valve covers is relatively small. And then I'd be able to adjust the valves.
Yes, it's only a few more bolts at this point. You may need to replace the gaskets again though if they are not soft anymore. I personally would skip the valve adjustment at this time as your compression numbers are very consistent. If you had an exhaust valve not fully closing you'd be losing compression but you are not, makes sense? The intake valves rarely need adjusting.
Last time I had my valve covers off I gave them a good scrub and cleaning and they looked much better. Then the engine blew 3 months later and it went to a scrapyard. Doh.
03-09-2023, 06:46 PM
#6
official vendor
official vendor
I made the executive decision to yank the valve covers. Easy enough at this point. Now I can paint or powder coat them.
@ 96RedRunner
, are you saying that you wouldn't try to paint them given the oxidation, or that I should take them out in order to paint?
@ gamefreakgc
Good suggestion on the valve adjustment, maybe I'll skip it then.
I'll plan to get new VC gaskets, even though the ones I removed still seem soft. Cheap insurance.
What about the half moons, tube seals, valve cover washers, and the camshaft seals? Should I replace any of them? I'll get some FIPG for the corners.
@ brillo_76
I'm at 211K.
03-09-2023, 06:56 PM
#7
Elite Member
Real Name: Jon
Elite Member
Real Name: Jon
At 214K you have time.. However, mostly its 250K -300K and above when adjustments are needed. Being your that far in. I probably would check valve clearances. Most likely they are still in the spec range given your compression check numbers.. As you can check them with the valve covers off..
Now to adjust them.. Your going to have to pull your timing belts and cams shafts out..:/ ( I know I am going to pull mine when I change my valve pan cover gasket here. ) As I am at 290K. Now, if they are in spec or that range leave them alone. If out of spec, just get the valves back in the range. You will drive yourself insane trying to get them perfect as its not worth it. This is why you get them in that range spec and call it good. (unless you want to take the camshafts out 25 times to get it exact then have at it. ) :-) Just my thoughts and its your call how you proceed.
__________________
7 3rd gens listed in the build thread (2 are parts mobiles)
Build Thread: https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer: https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information: https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
03-09-2023, 07:09 PM
#8
Elite Member
Elite Member
Check the clearances for piece of mind - it shouldn't be hard at this point. I too totally forgot to do it when I did my valve covers - though I'm up over 310k at this point.
Be careful how you clean those valve covers - if you use any media, it will be a huge pain to clean out of the crevices (mainly the PCV vent covers).
-Charlie
__________________
'99 4Runner SR5 Auto - 4WD swapped
'89 Camry Alltrac LE 3S-GTE 5spd
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Previous: '88 Camry Alltrac LE 3S-GE BEAMS, 90 Camry 3S-GTE, 90 Camry DX, '03 WRX wagon, '08 Outback XT
03-10-2023, 08:44 PM
#9
official vendor
official vendor
Quote:
@ phattyduck
- the powder coat guy wants to sandblast the castings before finishing them. Do you think I can safely tape off all the openings before taking them in? Or should l I look for a shop that does soda blasting?
03-09-2023, 09:10 PM
#10
Elite Member
Real Name: Jerod
Elite Member
Real Name: Jerod
@ 96RedRunner
@ gamefreakgc
@ brillo_76
I'm at 214K.
Based on the photo, it looks like the half moons were done at some point as there's still black FIPG there that hasn't rubbed off. Camshaft plugs yes, as they leak a lot. Do not touch the camshaft seals though. It's easy to mess them up and they rarely leak. How often do you see oil leaking on or behind the timing belt plate? Basically never. Also if you didn't replace the valve cover bolt grommets/washers or the spark tube seals when you did the valve covers then yes replace, if you already did them no leave them alone.
I still don't think you need a valve adjustment because of the time and frustration it is. You can do it without removing any camshafts if you buy the Toyota/Lexus valve adjustment tool (that's the name of the tool) but it will take you hours and you'll lose your mind halfway through. Many shops and dealerships will refuse doing the job for this very reason. Leave it alone...
03-09-2023, 09:47 PM
#11
Elite Member
Real Name: Jon
Elite Member
Real Name: Jon
Just curious why didn't you pull the camshafts out? I need to look into this Toyota/Lexus valve adjustment tool. one of mine is at the point I have to adjust mine...
Yes. I am not looking forward to this project at all.
Sent from my SM-A536V using Tapatalk
__________________
03-09-2023, 09:58 PM
#12
Elite Member
Real Name: Jerod
Elite Member
Real Name: Jerod
I've done it both ways, both pulling the camshafts and not. When I had the 3VZ-E engine I did it with the tool. It has a VERY steep learning curve that's extremely frustrating but once you get the hang of it the job gets easier.
I did the valve adjustment on my 5VZ-FE engine when I installed a set of performance camshafts and since I was taking them out it was simpler in some ways but not in others. I did the timing belt as the same time to make the hassle of lining up timing marks and all that worth my time.
There is a 3rd solution though. The exhaust camshafts do not have a sprocket on it and are fully contained in the cylinder head. You can very carefully thread a valve cover bolt in the threads on the spring-loaded intake camshaft gears and then, in order, remove the camshaft brackets and the exhaust camshaft. This then allows you full access to all of the exhaust shims without using the tool. Can be useful if that's all you have to do but the process of removing and installing the camshaft is extremely specific that I don't recommend doing it unless you read up on the FSM beforehand. It's also very easy to strip the aluminum threads in the cylinder head.
03-09-2023, 08:26 PM
#13
Elite Member
Elite Member
+100 on checking valve clearance while the covers are off.
I bead blasted my complete intake and VC tops and soaked theVC’s in acetone and mineral spirits to get as much carbon out of the baffle’s as possible.
03-09-2023, 10:43 PM
#14
Elite Member
Real Name: Jon
Elite Member
Real Name: Jon
I would. I appreciate
@ gamefreakgc
thoughts on the project as it makes sense, being he was putting performance camshafts. Maybe the person wants to thoroughly inspect the cam and the camshaft bearings.
I don't understand why people wouldn't remark the timing belt if they go that route. Recompress your belt tensioner and reuse your belt if it's very new.. [
like 25k or less] more than thet I just put a new belt in
I have the Fsm along with all of the tools except those toyota Lexus valve adjustment tools. So I just need those and 40 hours of swearing to get this job done...
I can also see people not wanting to do it also. I just at the point where I am going to have to. My valve covers I believe we're never done.. [ I had the rig from 215k] I can't even leave my window down without smelling burning oil. So, being my valve covers, they are coming off anyway. I will be checking and adjusting the valves.
Folks can do what they wish. But by the sounds of it. We have 3 options. I am glad I asked..
__________________
03-10-2023, 12:11 AM
#15
Senior Member
Real Name: Mark
Senior Member
Real Name: Mark
@ Spiker Engineering
, Take them off to paint or PC, too many nooks n crannys for me to be happy with end result.
If you have access to a ultrasonic cleaner good way to clean things.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
