Old 03-17-2023, 04:09 PM #16
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Originally Posted by Rushthezeppelin View Post
That definitely seems to be the consensus. Pretty excited about it. Already was a massive improvement doing the rack, tie rods and rack poly bushings but I'm definitely not at new vehicle ride quality levels. Might do the rear control arm bushings at some point too. Tell you what I'm glad the wandering steering is now gone, that stuff is fun when you are going up I70 and the chain ruts are throwing you around on a roller coaster ride.
I replaced all the original rear bushings a year or so ago and went with Whiteline poly bushings. I had noticeable wandering/sway at the rear when on the highway.
The difference was very noticeable. I also had approx 210K miles on those originals so most anything would have been an improvement.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 03-18-2023, 05:09 PM #17
Rushthezeppelin Rushthezeppelin is offline
Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about
I suspect at least one of my arms is original since the cam bolts were rusty while they are totally clean on the other (I suspect a PO had an issue with the other side trying to get it aligned and just replaced the whole arm at the request of a shop) and if so it has 278k on it.
Anyways just got back from buddy's shop. One side barely even needed anything at all on the press. I suspect I was super close to getting it with the bottle jack. Other side however, holy smokes was it in there. I'm betting we probably loaded it around 6 tons or so but that's just a guess based on how much it took before it went bang, and then bang some more and more. The washer that's pressed onto the sleeve was bent in just a tad from that, anymore and it might have just bent into the outer sleeve and pushed the rubber out with it then it would have been sawzall time >< It was in there really really good but we got it out. Biggest PITA part of this was knocking down the flange to get the bearing puller on. Getting it knocked down under the arm was a a chore, use a combo of punches and chisels and just kept fitting the puller on to see if it was good. Anyway my bushing saga is over and it's time to clean and paint the arms then put whiteline bushings in and then install them on the truck.
'98 SR5 5 Speed
Rushthezeppelin is offline   Reply With QuoteReply With Quote
Old 03-18-2023, 05:25 PM #18
Congrats, satisfying when it works out and even more so when they put up a fight
Almost there!
2002 SR5 Sport 4WD
Old 03-18-2023, 06:09 PM #19
Almost there!
Lol for sure. I've grown to love the bang a press makes when it just slipped several tons of stiction. Mechanical advantage is such an awesome thing.
'98 SR5 5 Speed
arm , hole , jack , secured , vice
FS [AZ]: ECGS 7.5" Diff CV Bushing/Removal Tool/Seal - 100 OBO AZSportRunner For Sale: T4R Items 2 01-18-2020 02:48 PM
UCA bushing question eelliiss 5th gen T4Rs 31 02-24-2018 08:59 PM
Removal tool for installing ECGS 8" Clamshell Bushing Geerlijd For Sale: T4R Items 0 08-13-2016 06:46 AM
LCA Bushing removal RunninUte 4th Gen T4Rs 3 02-22-2014 10:34 PM
swaybar bushing bracket removal....WAR!!!!! T4Rex. 3rd gen T4Rs 12 01-21-2013 08:38 AM
