04-07-2023, 03:26 PM
4Runner vs Tacoma, wheel frustrations
Hey folks, hoping there's a straight answer to this.
Bought a set of 32 x 11.5's on 15" alloys, which were fit and run on a '04 Taco, so same platform, and my understanding is, bolt pattern and offset are identical.
1996 4Runner, stock wheels and steels that I have are all 16".
Just found an OEM alloy 15" to mount the spare 32 on so everything is equal.
Now, the place that was putting a leveling kit in front, and tossing on the wheels/tires, called and said the wheels run into the brake caliper and dust shield. Continued, saying that they didn't think 15's would fit on the 4Runner.
Am I missing something, or does this place just not fully understand Toyotas (they're definitely a big American truck, bolt on accessory kinda place, not a full blown mechanics shop).
They suggested wheel spacers, "1.25" should be enough". I'm not a fan of *should*.
I thought I'd be needing them with the 32's anyway, so I'm okay with it, unless there's a bigger issue, or I'm doing something stupid, in which case, please share!
04-07-2023, 03:50 PM
Real Name: Patrick
Real Name: Patrick
Sounds like it's you not them. Only base model 4Runners came with the smaller front brakes to clear 15 inch wheels. I'm not even sure spacers will allow you to use 15 inch wheels. It would have been wise to check fitment before getting the tires mounted IMO.
04-07-2023, 04:01 PM
Real Name: Rich
Real Name: Rich
I’m no expert but from what I’ve heard SOME but not all 15s will clear cause I looked into it as well, what I gathered is that it’s a crapshoot due to some 15s having a larger inside barrel diameter than others. (I think that’s the correct term??)
If your running the tundra brake upgrade then no 15s will fit regardless but I’m assuming that’s not the case.
Also give it a look and see how much they rub the calipers. I’m no fan of shaving calipers to fit a wheel by any means but if even taking off a couple millimeters will make them fit then I’d just do that rather than spacers or throwing money at wheels till one fits.
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
04-07-2023, 04:06 PM
That's usually the problem...
Crap.
I had no idea there were "smaller brakes" etc. My (now annoying and expensive) mistake.
So Taco's all came with smaller brakes too, then? Or just the base model in them too?
I bought the set used, two tires were basically new, two were shot. Got two brand new tires, was going to use one of the old ones on the spare wheel I just bought.
In the interest of making this work if it can, safely?
Any thoughts or outside the box suggestions?
Really wasn't planning on blowing $2K plus on new wheels and tires, and all my other wheels are 16's so I can't use the tires on any of them.
Crap, crap, crap.
04-07-2023, 04:08 PM
Thanks, stock brakes from 1996, no upgrade there.
04-07-2023, 05:10 PM
Real Name: Patrick
Real Name: Patrick
Crap.
Crap, crap, crap.
You can try wheel spacers, but I don't see that really fixing the fitment issue. Any 4Runner/Tacoma equipped and sold with 15 inch wheels have the smaller front brakes in order to clear the 15 inch wheels.
04-07-2023, 08:37 PM
Real Name: Blair
Real Name: Blair
As suggested - go with 16s if you can. It make your life a lot easier.
04-08-2023, 10:36 AM
Thanks all.
TL/DR, I use a lot of words, hopefully they entertain, and inform, and create a better understanding so I can get a better solution, I appreciate this community very much. If novellas upset you, you can cut to the chase in the final paragraph!
I know this may be a simple thing to many, but much as I love Sophie, I'm not a tech nerd, and I just never will be.
I did install my own K+N CAI this week though. I don't do much off road at all, no deep stream fording, and in the northeast, dusty driving really isn't an issue, so I'm taking my chances, hoping to gain a few MPG, and the thing does make the truck drive a little more *something*, though perhaps it's my inner teenager appreciating the added kick to the Magnflow Overland stainless exhaust she got last year. All those were due to input from folks here.
Added the Gobi ladder this Spring, got some new StrongArm struts for my hatch (thanks to comments here), and she's looking ready to rock.
Then I find myself halfway up the sidewalls, spinning on this wheel tire thing that I already spent more than I'd budgeted for. So the question is, call in an expensive extraction, or slap down some recovery planks and hope they don't damage the truck in the process. (off roading analogy for illustrative purposes only)....
I had no idea there were different caliper sizes.
I do know in my past, late 80's early 90's Toyota pickups would warp their rotors on the regular, till I finally got a good tip (??) and did slotted rotors and ceramic pads, which stopped it cold.
Is that the 15" caliper? Too small for proper heat dissipation, so I'm buying hassle unless I change rotors and pads too?
Cause it looks like I can get 15" calipers for a couple hundred bucks, and be done with it. Which to me, right now, looks a whole lot better than dropping $1500 on 16" tires for my current steel rims which have slight rubbing on the frame with the 31x10.5's on there now. They're off my old '04 Taco, and may be creating the issue themselves (I've asked about this before on here).
So I have the stock alloys. But they need cosmetic love, so I'm adding to the $1500 in tires, to get no rub, but a wider tire so it may rub and need fixing too.
GAH!
So is spending $300 for 15" calipers a bad idea, in the face of spending thousands more to get something that works with 16" calipers, and causes me to end up with weird wheels/tires I can't likely get my money back out of?
And, PICS!
04-08-2023, 12:54 PM
Real Name: Rich
Real Name: Rich
With all the extra weight on there it wouldn’t be smart to downgrade your braking power. Also I understand why you want 15s but your running only slightly larger than stock tires. Is the 1/2” gain in sidewall really worth all this trouble?
There are some very good options in 16 like 265/75, 255/85 and 285/75
Personally I wouldn’t spend 300 bucks to end up with less braking power not to mention actually doing the work and rebleeding everything.
Also I’m not sure if the ABS will work with the smaller calipers as most vehicles that had that were 2wd base models that used a proportioning valve and not ABS but maybe I’m wrong.
04-08-2023, 02:23 PM
Thanks, good info. For all I knew, just two different caliper designs, but if braking is reduced, I'm not a fan.
Have a call in to the tire center to see if they'll work with me on a swap of the two new ones, if I buy two more, in 16". Hopefully they'll work with me.
04-10-2023, 01:18 PM
Okay, making progress here, but there always seems to be another hurdle.
Tire place will take back my 32/11.5/15's, and sell me 385/75/16's.
There's no direct 16", 32 x 11.5.
The 285/75 is 32.83" diameter versus 32.01" for the 32/11.5.
My limited understanding based on what I've read here is "33 inch is where things get trickier".
More suspension or body lifts? Body mods? I don't want to do that.
Currently running a couple year old OME 2" suspension lift, and just got this installed in front, on top of the 2" lift since the front end sat lower than the rear.
Just a moment...
Of course now the front's higher and I feel like I want another inch in back, but that's a separate thing unless someone thinks it's useful in the current context.
If the 285/75 pushes things too much, I'll need to revisit tire choices it seems.
Thanks again, got her muddy this weekend in some fields behind my GF's place, so she's happily dirty this morning.
04-10-2023, 01:57 PM
Threads like this only serve to confuse, too.
Making 285/75s fit on a 3rd Gen
Seems "some people make some fit, while others can't with lifts and cutting/hammering/shaving/modding.
Given 2" lift rear, now, 4.5" lift front, do I just need to add an inch to the rear and call it a day with any tire model in that size a sure fit? Or, or or....?
This crap makes my head swim....
04-10-2023, 01:59 PM
285/75-16 will require some clearancing. 265-75-16 (metric 32's) are the max before mods - only ~1" up from the stock 16" wheel size.
15" wheel 4Runners had smaller brakes (calipers and rotors up front, smaller rear wheel cylinder to match), smaller overall diameter tires (~29" instead of ~31") and different axle ratios to match. Minor shock/spring tuning differences too, but not enough to matter for this discussion.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
04-10-2023, 02:22 PM
Real Name: Rich
Real Name: Rich
Are you looking for a MT tire or considering one? I’d go with 255/85/16.
They are taller than the 285s but with 3rd gens that’s not where the problem lies.
It’s the width that’s the issue.
After about 10 mins of clearancing I fit 255/85s with no front lift at all and I have a winch upfront weighing it down. I am running 1.25 inch spacers for my tundra brakes so that will also have an effect.
I’m sure your probably not looking for MTs but I thought I’d throw that out there
