Old 04-16-2023, 10:48 PM #1
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
Replacing Window Sprayer Pump
My rear window sprayer stopped working a while ago. I tried adding more fluid thinking it was just low but that did nothing, and eventually noticed I couldn't hear the pump.
What's the best approach to replacing the pump? I've seen conflicting things about the location of it so I'd like to be sure before I go and pull one at a junkyard.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 04-17-2023, 12:01 AM #2
HiLife HiLife is offline
Pumps are located on the outside of the washer reservoir. Easy as undoing the electrical clip connected to the motor, and pulling motor.
Washer motor is held inplace in the resrvoir by a rubber grommit. So, twist to break the rubber/motor connection and pull straight out, or pull at an angle.
There are separate motors for the front and rear. Cant remember which one was which.
Old 04-17-2023, 12:30 AM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
If I remember correctly, the pumps are identical. Check the part numbers printed on the pumps but I believe they are the same.
326WHP 347TQ
Old 04-17-2023, 01:16 AM #4
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
The aftermarket pump motors are pretty cheap. Like $25. OEM pumps show at $62.
pluton is offline   Reply With QuoteReply With Quote
Old 04-17-2023, 06:13 PM #5
Thanks guys, I got it out and replaced but that still hasn't fixed my problem of the rear sprayer not working.
I'm kinda stumped now because I have replaced the pump, the wiper stalk and the fuse and it still doesn't engage the pump
281k Miles
Build Thread
Old 04-17-2023, 09:57 PM #6
Did you check off power to the pump and a clog free rear spray nossle?
Old 04-17-2023, 10:35 PM #7
As far as I know yes, the pump is not getting power, I replaced the wiper stalk and the wiper fuse today thinking those may be the issue but that didn't change anything.
I looked for a clog in the back but figured that since the pump isn't getting power that won't matter.
I don't know where to start to troubleshoot the power issue though
281k Miles
Build Thread
approach , pump , replacing , sprayer , window
Reap window sprayer not working. Sgtausy 3rd gen T4Rs 12 04-18-2023 12:23 PM
Differential fluid weed sprayer pump octanejunkie Maintenance/Detailing 4 11-12-2022 08:33 PM
replacing fuel pump Wayne 3rd gen T4Rs 25 10-20-2014 09:45 PM
Pump Sprayer for Gear Oil? Icychap Maintenance/Detailing 5 03-27-2013 09:57 PM
Replacing oil pump & oil pan gasket 95 3.0 mikedks Classic T4Rs 2 05-29-2011 01:57 PM
