Old 04-20-2023, 08:52 PM #1
Gongshow's Avatar
Gongshow Gongshow is offline
Real Name: Brian
Gongshow is on a distinguished road
Gongshow's Avatar
Real Name: Brian
P0500 Pending Fault & Blown Fuse
Hey guys,
1999 SR5 3.4L 4x4 auto trans with J-Shift. I blew the 10A Display fuse on the lower left fuse block on the driver's side. I lost all readings on the instrument cluster and the fan blower control. I drove for a little bit and it drained the battery.
I got towed home, recharged the battery, located the blown fuse, replaced it and everything was working as normal, battery shows 14.6 volts and charging normally. I drove about 3 miles away to pick up mail, when I started the engine again, the fuse popped again. I replaced it, started up again and it popped again.
On the way home the Torque Pro app alerted me to the Pending P0500 Vehicle Speed Sensor fault code. Last year I replaced the instrument cluster lights with LEDs and a few months ago they began flickering. Has anyone ever encountered this?
I'm not sure where I'd begin trying to locate a short in the wiring or how this would affect the battery from charging. Any help would be appreciated.
"Arguing like an idiot is like playing chess with a pigeon; no matter how good you are at chess, the pigeon will knock over the pieces, **** all over the board and then strut around like it's victorious." http://millcreekmasons.org
Gongshow is offline   Reply With QuoteReply With Quote
Old 04-20-2023, 09:28 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You have something on your gauge circuit pulling more than 10 amps. Can you measure the Amp draw across that gauge circuit?
Then pull the electrical wiring diagrams to see what all is connected to that fuse.
Then, systematically check each component until you find the issue..
Old 04-20-2023, 11:21 PM #3
HiLife HiLife is offline
The P0500 is a hint on what could be causing the fuse to pop. It not necessarily the answer to your issue but, it's a place to start your troubleshooting.
Check under the car to make sure the wiring to the abs wheel sensors at each wheel are not obviously shorting out to ground. It's free and should be easy to do.
Old 04-21-2023, 01:40 PM #4
If the gauge cluster has no power, the ECU will throw that code. Fix the fuse blowing issue and that will be resolved.
I had a random one - the flex circuit board on the back of my cluster went bad a few years ago. Didn't blow fuses though, so less likely to be the issue here.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-21-2023, 07:21 PM #5
The P0500 is a secondary code then.
What op can do then is to remove the gauge cluster and replace the fuse, the fuse should not blow when ignition is powered on. If the fuse blows with the cluster out of the loop, then the it's something inbetween the 10 amp fuse and the cluster wires.
Only thing connected to that 10 amp circuit is the gauge cluster itself and a separate vehicle speed sensor that looks like that's part of the gauge cluster.
If op then slips in the gauge cluter and fuse then blows, it very well could be in the cluster itself or, one other sensor that also plugs into the cluster.
Old 10-15-2023, 09:36 AM #6
corvidcine corvidcine is offline
corvidcine is on a distinguished road
Originally Posted by Gongshow View Post
Hey guys,
Hey there. Did you ever figure out the issue? I swapped gauge clusters already, and drove about the same 3 miles and ran into the same problem. Also, whenever the fuse pops, I lose overdrive.
I'm guessing from the final post on this, the only other option is that the VSS is bad, or the wiring is bust.
Thanks!
corvidcine is offline   Reply With QuoteReply With Quote
battery , charging , drove , fuse , replaced
Gauges and AC not working. Blown fuse, replaced fuse, blown again. What do? blairracd 3rd gen T4Rs 12 04-03-2021 05:55 PM
Pending Fault P2714 Pressure Control Sol D Performance or Stuck Off B.E. Coyote 4th Gen T4Rs 1 07-11-2020 10:04 AM
UBJ boot break IMMEDIATELY after lift. My fault or shops fault? 4BUMR 3rd gen T4Rs 33 10-12-2017 09:29 PM
Blown Fuse or Blown ECU? pcr777 3rd gen T4Rs 3 04-23-2013 01:40 AM
Blown fuse? FunnerRunner Classic T4Rs 1 04-23-2009 11:41 PM
