Old 05-04-2023, 09:57 AM #16
Recurring issues that should’ve been fixed
It took me three drives in rain and stopping hard enough to activate the abs, each time after the abs activated my pedal went soft. Now I have a firm pedal
There might be a way to operate the abs motor from the test block on the intake manifold.
Old 05-04-2023, 03:37 PM #17
Originally Posted by brillo_76 View Post
The system is harder to bleed because of the abs. Air can get it in there and harder to get it out because of its location and harder to activate when bleeding.
This is why alot of folks will bleed. Take the rig down a dirt road a few times to activate the abs then bleed it again.
Not only that, but there is a special procedure for the '96-'00 trucks, and a different special procedure for the '01-'02 trucks for bleeding...
Here's the '96-'00 procedure:
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-05-2023, 02:26 PM #18
blairracd's Avatar
blairracd blairracd is offline
blairracd is on a distinguished road
blairracd's Avatar
I actually did this prior to seeing your message and it helped a little. Still going to bleed them. Any tips for doing it yourself?
Living and breathing and bleeding Toyota
https://imgur.com/a/KvwQdyO
RIP my ‘96.
blairracd is offline   Reply With QuoteReply With Quote
Old 05-09-2023, 09:43 AM #19
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Well, what I did was go to speed bleeders. As that's the easiest way of bleeding yourself.
Best to have someone pumping while the other is at the bleeder otherwise...
Old 05-09-2023, 10:36 AM #20
Buy a motive pro pressure bleeder.
Or cut a board long enough to hold the brake pedal to the floor and wedge it into the back of the seat. I open bleeder and depress the brake all the way to the floor and wedge it in place with the piece of wood. Then I close the bleeder and then remove the board.
I’m not a fan of speed bleeders but there better than nothing.
Old 05-11-2023, 01:17 AM #21
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
I used a piece of 1" pvc pipe cut 24" long. Wedged it between the brake pedal and the front of the stock seat bottom. Went underneath, bled, came back and reset the pipe, repeat, repeat, etc. It worked. Next time I paid a local shop. But it worked.
pluton is offline   Reply With QuoteReply With Quote
brakes , fluid , issues , oil , year
Fixed transmission overheating issues! OffKamber 5th gen T4Rs 8 09-15-2021 10:06 PM
Engine issues on diesel....Again *FIXED* Mattew Classic T4Rs 2 06-13-2019 01:05 AM
Fixed my ABS issues my92t4r 3rd gen T4Rs 4 10-14-2014 03:01 PM
Got the back glass motor fixed and now more issues Gremcat Classic T4Rs 2 04-30-2014 09:41 PM
Recurring fan clutch issues Mr Man 3rd gen T4Rs 0 04-22-2011 11:43 PM
