Old 05-30-2023, 11:56 AM #1
hawkcharmer's Avatar
hawkcharmer hawkcharmer is offline
hawkcharmer is on a distinguished road
Do I really need a relay for 7 Harbor Freight Rock lights?
Hello,
Just picked up 8 Harbor Freight LED Rock lights. I will only use 7 lights.
Each light is 4.4W each, about 0.42A each
30.8W total / 2.94A total
I was thinking of running all 7 lights to battery or my 6 blade blue sea fuse block under the steering wheel and using factory OEM toyota switch.
I will also be using 16 Gauge wire. This should be fine. The runs are not that long
The switch is 21 Amp at 14 Volts DC.
Will I be fine running it like this or do I absolutely need a relay?
Any feedback is greatly appreciated. Thank You
1999 4Runner SR5, 3.4L 5VZ-FE V6 | Tundra/890 coils | 5100 Bilsteins all around l 199mm Tundra brake upgrade | 265/75/16 Falken Wildpeak AT3 tires | ARB Bull Bar
hawkcharmer is offline   Reply With QuoteReply With Quote
Old 05-30-2023, 12:05 PM #2
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
Originally Posted by hawkcharmer View Post
Hello,
You don't explicitly "need" one, but having a relay at least in my eyes completely separates the circuit so you won't have any draw or other problems with amperage
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 05-30-2023, 12:15 PM #3
Would it be separated if I run it to my blue sea fuse box?
Old 05-30-2023, 12:30 PM #4
it would, but the fuse box only makes it so the accessories don't have to be hooked up to the battery directly
281k Miles
Build Thread
Old 05-30-2023, 12:35 PM #5
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
I have no experience with those specific lights, but cheap LEDs can add a TON of noise to your electrical system. Bad enough that you might be able to hear it in your radio.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
fine , lights , rock , switch , total
More Harbor Freight Jack Stand Problems - Today’s Email from Harbor Freight RichinRidgewood General Discussions 0 07-10-2020 07:24 AM
Harbor Freight Recall 3bears General Discussions 9 05-21-2020 05:58 AM
Harbor Freight winch octanejunkie Off-Roading 26 04-17-2018 10:38 AM
Harbor freight Bed liner MadeInMaine 5th gen T4Rs 4 01-22-2016 04:42 PM
Harbor Freight 25% off Today only Dagwoods 5th gen T4Rs 0 03-31-2013 08:12 PM
