Originally Posted by busmup808
I did this mod back in 2002 in my FZJ80 for a 8273 WARN winch. I’ve had this 1st gen XRC 8 comp winch winch 2014 that is a 3 pin. For the life of me I can’t remember how to wire it up. Mahaloz in advance for a dumb question FSM below: B4 is the switch
I used this switch in the rear to make my window go down so there should be five wires that come from that
Green with red stripe is for up
Green with yellow stripe is for down
White with black stripe is the ground
There would be two other wires in the harness which are for illumination
The switch grounds the wire that corresponds with what function you want on the switch
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
