Old 06-09-2023, 08:24 PM #1
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE )
Hey Dudes, @infamousRNR created a 7-Part video series on how to remove and reinstall the cylinder heads on the 5VZ engine.
There’s many reasons why you might find yourself needing to remove the heads. You could have a suspected bad head gasket or cracked head. You could have a suspected issue with the head, like a burnt valve, and you need to rebuild the head. It could be because you’re rebuilding the entire engine. Whatever your reason to pull the cylinder heads, this video series will walk you through all the steps necessary to get the job done successfully.
Happy Wrenching and Sic Mods for All!
PART 1
Old 06-09-2023, 08:25 PM #2
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
PART 2
Old 06-09-2023, 08:25 PM #3
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
PART 3
Old 06-09-2023, 08:26 PM #4
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
PART 4
Old 06-09-2023, 08:26 PM #5
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
PART 5
Old 06-09-2023, 08:26 PM #6
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
PART 6
Old 06-09-2023, 08:27 PM #7
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
PART 7
Old 06-09-2023, 09:22 PM #8
Krispydixie Krispydixie is offline
Real Name: Kris Dixon
Krispydixie is on a distinguished road
Thank you thank you thank you!!!
Thank you so much man I needed this so bad!
[/QUOTE]
Krispydixie is offline   Reply With QuoteReply With Quote
Old 06-12-2023, 03:30 PM #9
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
The video series I hope I'll never have to use but really glad it's here. @mtbtim & @infamousRNR , thank you.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 06-13-2023, 02:54 PM #10
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Part 2 is live. Go to Post #2.
Old 06-13-2023, 08:53 PM #11
19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold
I recommend the YotaShop head replacement kit. It comes with every thing from valve stem seals to exhaust donuts to the knock sensor harness to headbolts.
over the years I've used three. and have a drawer of extras.
Old 06-18-2023, 05:17 PM #12
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Part 3 is live!
Old 06-18-2023, 07:41 PM #13
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
watching this series. Very well done. Better quality video upgrades.
When using those inductive heaters. Make sure the exhaust nuts are very cool. If the nuts and studs are hot they expand its possible the maybe caused the nuts to seize ar the ends as well.
After nuts move.... hit them with wd 40 or equivalent to cool them down, which will shrink the expansion and help come off easier....
Old 06-18-2023, 09:47 PM #14
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
That's quite the job and even more work to film it. It's the most labor intensive engine repair other than replacing the engine itself. Thanks for taking the time to film it all on top of it.
326WHP 347TQ
Old 06-18-2023, 09:50 PM #15
After my second round,I pulled the exhaust studs out and left the exhaust intact. It saved so much time removing the heads.
engine , head , heads , series , suspected
V6 engine replacement vs head gasket repair ??? zguy1 4th Gen T4Rs 142 09-14-2023 05:05 PM
Head Gasket or Cracked Head 02 4runner - Colorado any mechanics out there? vanderwiel 3rd gen T4Rs 9 09-26-2021 09:10 PM
Could this be a cracked head or gasket issue? (UV dye pic) Cycleandsurf 3rd gen T4Rs 3 02-07-2021 06:02 PM
head gasket repair leads to piston through head theresa4586 3rd gen T4Rs 37 03-20-2013 01:20 AM
blown head gasket, then warped head, now new engine straightjacket 4th Gen T4Rs 42 05-12-2012 09:45 PM
