ABS light on after bearing check
T4Rscott
Hi all,
Can someone tell me why my ABS light would be on after having the truck up on jack stands checking for a bad wheel bearing.
I did have it in 4wd so I could see if the fronts were ok.
Hi all,
Might have had some rust get on the sensor.
If early years 96 to 2000. You have to use a paperclip on the odb 1 connector in your engine bay. Then it will flash out your code on the abs light.
The light pattern will tell you exactly what the issue is. :)
